what wax?
2002 S500 black/java/2011 Escalade (wifes)
what wax?
Can someone please let me know what waxes etc. I need to get a high gloss on my 02' Black S500? It seems no matter what I use they all seem the same ho hum waxes that never really look so great and wear off after a day or two.
Thanks!
Thanks!
I never use ZAINO.
Location: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Best wax or Sealant:
Is there a best? In my opinion- No!
While its true many of the chemicals used in the formulation of car care products are the same (or at least very similar) Having used a variety of different products I can tell one from another and field testing shows that not all have the durability either, some simply out perform others in many categories and react differently when applied to different paint types, paint hardness, colour, or varied paint surface conditions.
Ultimately the best wax or sealant will prove to be the one that best meets its user's objectives. If a product is not working for you experiment until you find one that’s suitable for your needs.
There is no one product that can produce all of the properties for an optically perfect shine, however; for high surface gloss and surface reflectance-a polymer sealant, which also provides durability. Detailing enthusiasts consider shine as only one attribute of a protective wax or sealant. They are equally concerned with; ease of application, resistance to abrasion, atmospheric contamination and weathering.
a) For depth of shine - Carnauba wax (also provides a sacrificial and easily renewable barrier against airborne contaminants (Swissvax, Zymol, Souveran)
b) For clarity - long term durability and protection apply a polymer sealant (Zaino Z2PRO™ + ZFX™ Flash Cure Accelerator Additive) to a carefully prepared level, clean paint surface.
c) Optically perfect shine – apply a optically clear polymer sealant and add a Carnauba wax, a Glaze or
Zaino Z-8™ Grand Finale Spray Seal as a last step product (LSP).
d) High heat conditions - a polymer sealant, one that includes a UVR protection (Zaino) and a sacrificial wax (Collinite (actually a polymer/wax) Liquid Insulator Wax (No. 845)
e) Harsh winter – Klasse All In One (AIO) Klasse Sealant Glaze (SG) x 2, Collinite # 845 Liquid Insulator Wax or # 476s Super Doublecoat Auto Wax x 2. If you apply a final layer of wax without buffing it will provide more protection / durability (especial for vehicle storage purposes).
f) The aesthetics of a vehicle appearance is very subjective to say the least, the only best wax or sealant that really matters is what looks 'best' to you and meets the criteria you set for it.
g) The final result can only be as good as the surface it’s applied to. It really is all dependants upon, process over product; 85% preparation, 5% product suitability, 7% application methodology and the balance is in the ‘guy’ of the beholder. The other variables are; a detailer’s knowledge of paint type, experience with a given product and skill level and experience with machine polisher.
C 240 4-Matic
Wax
Check out Groitsgarage.com. I use their carnuba wax and it really works well. Doesn't go away quickly, but is a bit more work. The quick shine spray works good to remove light dust etc. between washes. Lots of nice car care products. Not the cheapest, but hey, you have a Benz.
02 E320 Blk, 09 E350 Blk
Can I....
Btw, Its a blk color...
Thanks in advance...
I think applying a sealant first like the AIO and HGSG is smart because it gives you a strong underlying coat of protection. I also really like to apply a wax on top of the sealant for added gloss and protection. Assuming you're using a carnauba wax you will not remove the underlying coat of Klasse products. Let me know if you have any other questions, or if you need additional recommendations.
Greg @ Detailed Image
You get a great shine from paint correction done by (machine) during polishing. Paint prep prior to glaze/sealant/wax application is paramount to getting incredible results.
Mezerna makes the best poilishes in the world and some specifically made for and used by Mercedes. I would highly suggest PO106ff for minor swirls and SIP (Super Intensive Polish) for more intense scratches and swirling. If the imperfections in the paint aren't removed, you will not get that showroom shine because the paint won't reflect properly.
Jetseal109 is THE best sealant. Pinnacle souveran is a good wax as is Chemical Guys 50/50 or Pete's 53. Lusso Oro I have heard is excellent as well.
-Dave
The Klasse High Gloss Sealant Glaze (aka HGSG) is a sealant. Ideally you would want to wait 12+ hours for any sealant to fully cure before applying another coat of sealant or wax. I suggest waiting a bare minimum of one hour but twelve+ would be more ideal. The HGSG looks outstanding for a sealant in my opinion. It gives a great deep gloss and looks really reflective. It is also one of the strongest forms of protection I've ever used. The only major downside is that it is a little more challenging to remove. Apply the product very thin and you may want to use a little quick detailer during the removal process with a microfiber towel. Let me know if you would like any more information.
Kawasaki
I would highly suggest investing in a properly done detail (please search for a quality detailer before taking your car to a local car wash and getting a full detail for $100)
As for waxes, I'm a fan of all chemical guys products. Especially if you are looking for long times protection and a nice shine, CG 5050's is the product to get. If you do want that extra time, I would say seal the car with either CG Jetseal or Wet Shine and then throw a coat of wax on after, let it set, and wipe it off. Works like magic.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
