What does sheeting water off the car mean?
I've got into the habit of using a clean water blade, to get most of the standing water off. After that I go over the car with one of those tech, squeegy cloths that soak up the water. Finally I go over the body work with a clean microfiber.
The idea is not to rub the paintwork if you don't have to. My way I use 3 different across my paintwork. Any little bit of grit in going to be dragged over all your paint. The sheeting way is only water. I did try it once, but I didn't get good results.
Hope this explains enough.
Peace,
jim
Let me know if you have any other questions about these products or anything else related to detailing.
Greg @ Detailed Image
I rarely use a microfiber or anything else to dry anymore. I typically use a Metro Dryer which provides filtered, slightly warmed clean air via a soft neoprene nozzle which doesn't scratch the surface. It has the benefits of:
1) Not creating any (even fine) scratches when drying since nothing but filtered air is touching the paint. This is particularly helpful for me when cleaning my motorcycle.
2) Getting water out of cracks and crevices so that if I want to apply wax, the vehicle is ready faster
I don't use the vac n'dry because I only want the "dryer" portion and don't want to risk any contamination from using the item as a vac. I have a separate shop vac for the "vac" work.
