If you could only pick one...?
I have no desire to spend endless hours washing, drying, clay bar-ing, polishing, waxing, etc.... I want to wash, dry, and use ONE other product.
What product would you chose? Why?
2005 E55 ///AMG
Wash/dry/detailing spritz is the usual. About every six months you should wash/dry/polish/sealant. Claying is your call, but probably once a year would be good...but not absolutely critical.
Edit: My personal preference is Meguiar's Gold Class Wash, Dry with Blower, and Wolfgang detailing spritz. I use Wolfgang polish and paint sealant every 3-6 months.
2005 E55 ///AMG
Personally, I prefer shorter periods between sealant applications (every 3 months), but that is not what you seem to want.
There are plenty of people that wax/seal every month also.
I would suggest using an AIO (All In One) product that helps polish and protect the paint. It helps remove light oxidation, contaminants, etc. while simultaneously shinning and protecting the paint. They are easy to use and my "go to" product for any one step process. The Klasse All In One and the Poorboy's World Polish w/Sealant would be my two favorite products. Let me know if you need any additional recommendations.
Greg @ Detailed Image
Thanks for the recommendations!
I have a Ryobi 6" Orbital, but the bonnets are just junk. I'm thinking of picking up a new orbital too for a "once every 6 months" polish/sealant job.
C350
Ok, order looks as follows:
Chemical Guys: Maxi Suds - 128 oz 1 $19.99
DI Accessories: Sheepskin Wash Mitt w/no thum 1 $8.99
Klasse: All In One (AIO) - 500 ml 1 $27.99
Klasse: High Gloss Sealant Glaze (HGSG) - 500 ml 1 $20.99
The 10% off coupon code didn't seem to work, so I emailed support to see if I could get the discount. I'm looking forward to getting everything in!
Thanks Greg and everyone else for your recommendations.
2005 E55 ///AMG
+1...I have been using the Lucas Instant Detail Spray for about a year now and it works very well...Wolfgang 3.0 with Pinnacle Carnuba on top is the best I've found so far.
I used the Chemical Guys Maxi Suds, and the Klasse AIO today and i'm VERY impressed.
The Maxi Suds loosened grim and grit from a few days rain and road grit quickly and easily. Washing took no time at all. The Klasse AIO might be the single greatest product I've ever used. Application takes no time, and wiping it off is clean and easy. I haven't used the Klasse sealant yet, but I look forward to doing so!
A+ all around!
A+ all around!
Super Moderator
2007 C230SS; 2014 ML350 BT
A+ all around!
A+ all around!
2005 C55 AMG
Be really careful with the Klasse Sealant Glaze in put it on REALLY, REALLY thin. If you put it on too thick it is a really PITA to get off and will streak. My recommendation is to thin it with water about 3:1 and apply it, let is sit overnight, then wipe it off. 2-3 coats will give incredible shine and will be VERY durable.
C350 black/black
Just to make sure by 3 in 1, do you mean 3 part water mix with 1 part hg?
Super Moderator
I had a tough time buffing it offf. I usually wipe the one that does not come off during buffing with a damp towel before I put on another coat. Is it a good way to get those remaining residue off? If not, what would you recommend?
