removing swirl marks?
Al Boston, or another professional, can u guys tell me how to remove swirl marks , without using a buffing machine, and what product do i use. Thanx
2quik,
Can you define for us just how bad the swirls are? I mean does it look like a newbie took a wheel polisher and a wool pad to it or are the swirls on the light side, more like spider webbing?
More likely than not if just using human power you will do more filling and hiding than actually removal of the swirls.
Get back withus,
Anthony
Get back withus,
Anthony
Mercedes-Benz
people are successful with using 3M FI2 by hand (intermezzo has) but I have never tried it myself. I do all abrasives by machine because it is so much easier. Do yourself a favor and get a PC or a rotary buffer.
FI2 by hand would be unbearable for most I would think. DACP is a much better alternative if you don't have a PC. Of course, PCs make swirl removal MUCH easier...best 100 bucks I've spent.
E320
Oggle, that is a great link. I learned a lot from that write-up when I was learning to use a PC. 2quik, just remember to be patient during the learning process and you'll do great. It's really safe and easy to learn. Check out my thread on my detail of my CLK. I removed the swirls with a PC and some 3M SMR.
Mercedes-Benz
Most ppl have trouble using FI-II by hand because of their technique. These are the procedures I follow:
Fold a cotton terry cloth so it fits nicely into your hand. I usually fold a 15x15" terry cloth three times (8th of original size) and then use the edges of the final fold as the handle and flatten out the opposite edge. Using the towel this way allows me to hold the towel in a fist and get nice even pressure on the paint.
Do NOT use a small yellow foam applicator....you'll end up with more swirls (hazing) than you started with. It's impossible to apply even pressure with these things, as your fingers will be doing most of the work.
Mist your cotton towel with water several times to soften it up a bit.
Apply a nice circle of product onto the area of the towel that'll be in contact with the paint.
Work in 2'x2' sections at a time.
Focus on applying gentle EVEN pressure using your entire hand in wide circular motions (this goes against everything written here, but I feel using circular motions works better for me).
Continue working the product until the surface is nearly clear and dry.
Buff residue with an MF towel.
Spray the area you just did with a 50/50 solution of water and IPA, let it sit for 30 seconds and wipe. Are the swirls gone? If not, repeat. If yes, then move on to the next section.
Keep in mind, although this method works really well for me, removing swirls by hand is very tiring and requires a lot of stamina. If you're aren't privvy to this kind of detailing session, consider investing in a machine and using AlBoston's tips in his sticky thread. They are based on methods he's tried many times with fantastic results.
