I Give My Car A Blow, After Washing...
I start on the top blowing the water to the front or back and do window's next then the hood and trunk then the body sides, front and back. Nothing but air touches the car. No rubbing, wiping scratches etc. If you want to use a Baja Squeegee first it goes even quicker. I have never bumped the car with the blower nozzle but if your are afraid you might, cut the toe end off an old sock and roll up and put on the end of your blower to protect.
Anyone else ever done this? Below is picture of what I use, Toro $49 or Weed-eater.
Quick reply to below: {Glad to hear others do it. I've never blown dirt onto my car, I do have a cement driveway and the blower is always about 3 feet above the ground. I guess it would be about the same as driving down the road as far as blowing dirt. But nothing like getting a sand grain in your chamois
About the only danger I can see with a leaf blow is blowing dust/dirt and having it blow onto the paint at a fairly high speed. That could cause scratches. Oh yeah, and all your neighbors will probably laugh at you with a leaf blow drying the car :p
For over 10 years, after washing my car I use a leaf blower to blow all the water off my car. Electric {or Gas} hand held leaf blower is what I use after washing to "blow dry" my car. I've never seen anyone else do it. It works GREAT and dries the car spotless in just a few minutes. All water is blown out of every nook, cranny,seam and trim piece. Window's blow dry spotless.
1) Blew lots of dust onto the car. Maybe the floor was dirty and I needed to wet it first.
2) Water would just dry on the car as I'm blowing and leave water marks.
How do you guys get around the above?
Indispensable for cracks, crevices, side mirror and molding gaps, etc...
i use it at least 3 times a week when i was my cars. its great. for the people saying it drys the car to much are just doing it to long. all you have to do is let the blower blow by the water for about 2 seconds and then dont go back. if u are using it to completly get all the water off it will leave marks at least on a black car. even if u dont do it all the way but do it to much it will still leave some water marks and when u get a chance to dry the car it will already be dry. i only use it a lilttle bit, then dry the car with a towel.
In warmer weather I just towel it dry with cotton towels.
I use my 2-stroke gas leaf blower to dry off the car after washing it during the winter. It beats driving around the block at 80 mph!!
"I wouldn't recommend using a gas leaf blower as gasoline mist from the blower can end up getting on your car."
Gasoline mist? Gas leaf blowers do not blow gasoline mist...flame throwers do! Worst you get is stinky fumes. It's no worse than following a diesel car on the road! The little engine exhaust blows out the side of the engine, not the blower nozzle. I've used both with excellent results.
