Monoblock wheel maintenance
'14 CLA 45
There are waxes specifically for wheels. Later on, clean them only with water. If you can not get them clean with just water, use a safe wheel cleaner such as P21S or Sonax. DO NOT buy any from stores such as advanced auto parts.
Location: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Wheel Surface Sealants
Apply a sealant after cleaning to make maintenance easier, use a synthetic polymer sealant to protect wheel surfaces as it has a high melting point (350.oF +) The melting point of an organic wax (180.oF+) is too low for the normal temperatures encountered by vehicle wheel surfaces (195.oF+) Also using a polymer sealant enables the wheel surface to resist the adhesion of brake dust, dust and dirt, and road grime and it makes surface cleaning much easier using only a car wash concentrate and water solution.
WheelWax - safe for all wheels, painted, anodized, polished or clear coated. Just wipe it on, let it dry to a haze and wipe it off. For maximum shine, rinse the wheels with cool water and buff to a high shine.
Swissvax Autobahn Wheel Wax - this product was developed for German customers of fast motor cars with alloy or magnesium wheels. The product has been tested on German Autobahns on cars with top speeds of 185 MPH (300 KPM) in Switzerland during the winter. Switzerland has one of the harshest road climates in the world using salt and harsh winter chemicals, and on racetracks in Austria and Germany.
G|techniqu S1 SmartMetal Nanocoat – a one-component clear coating based upon chemical nanotechnology that offers a transparent and optically neutral coating for smooth, non absorbing surfaces. Sealed surfaces are easy to maintain, without the need for any special cleansing agents, and are resistant to fresh soiling of the surfaces.
Used on metals offers a long-life protection against corrosion and because of its long lasting adhesion to the base material surface, and is highly resistant to mechanical and chemical attack as well as offering exceptional UV protection. For use on stainless-steel, chrome, aluminium, brass, copper and already coated surfaces. Not intended for use on glass or on plastic materials.
To name but a few
To name but a few
shaggy_x (11-26-2021)
