Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Polishing a 1972 original finish
Old Sep 18, 2010 | 06:18 PM
euromedic's Avatar
2002 C320 Wagon
I am about to become a privileged owner of a 1972 220D white sedan. The car has always been garaged, and as such the original paint finish is still in fabulous shape. The trunk has quite a few fine scratches. Curious if there are specialty polish products out there for a car this age, or if using Zymol is acceptable. Any other advice is appreciated, of course
Old Sep 18, 2010 | 09:34 PM
ohlord's Avatar
Menzerna
properautocare.com
wash clay polish glaze seal wax your white will shine.
Old Sep 19, 2010 | 09:58 AM
sidwynder's Avatar
none
The original owner may have some advice on what they did to keep the paint in such good shape. You may want to use the same products.
You say the paint looks good now and your only concern is some fine scratches in the trunk.
Without seeing the type of scratches on your trunk any advice you get will be in general.
Which means that the solution proposed is non specific to you.
Your specific problem may or may not require polish.
Claying a car won't have any effect on scratches in the paint.
30 year old white paint is unforgiving. You start rubbing and buffing on it and it could change shades on you and force you to do the entire car.
If the paint is in as good a shape as you say, abrasives are the last thing you want to use on a garaged kept white car that's over three decades old.
Non abrasive options, wax, conditioner and glaze all work well protecting and or preserving the paint while hiding or filling fine scratches in the paint.
Heavier scratches would need buffing and polishing for removal.
The question is how bad are the scratches
Old Sep 20, 2010 | 02:42 PM
euromedic's Avatar
2002 C320 Wagon
I believe that most of the scratches on the trunk will be less obvious once a wax is applied. I concur about polishing compound not being used on the finish, probably will use that lightly on chrome trim. Thanks for the responses. Car will be washed, gently clayed, then waxed. Images forthcoming
Old Sep 20, 2010 | 05:09 PM
ohlord's Avatar
Not compound
Polish big difference.
Compound abrades polish burnishes.
Menzerna polish will restore the shine to jewel like condition the seal and wax will protect it.
Old Sep 21, 2010 | 11:36 AM
slik560's Avatar
SOLD both: 1987 560SL 2003 ML320
Look forward to seeing photos. Even without clear coat, MB white paint is pretty tough. The pigment is titanium dioxide, which is hard stuff. I used Meguiar's 105/205 polishes, followed with Show Car Glaze #7 and then topped with NXT 2.0 sealant...then #26 wax on top.
Good luck - it'll turn out great!
