Wax on plastic surfaces - removal
What do I use to remove this?
Thanks everyone !
Need some type of solvent that is not going to harm the plastic
As suggested before, then use Back to Black or any good plastic treatment to rejuvenate the plastic back to original color.
I use blue painter's tape to mask off the edges before waxing, it is quick and very effective, for your next detailing session.
Good luck!
Good luck!
Try some window cleaner sprayed liberally on a cloth but don't rub too hard. Your black plastic trim is actually vinyl, solvents and cleaning agents when rubbed hard into it can fade the finish in that spot. Prepsol (wax and grease removing paint cleaner) is a stronger solvent but has more chance of fading the vinyl, but better chance of removing some of the compounds in commercial waxes. Alkalai salts like some citrus based cleaners are also good but again, don't rub too hard, use more liquid than pressure and try to tease the wax out of the texture rather than scrape it. A soft, old toothbrush and something gentle like window cleaner are a good idea.
If you find you do fade the vinyl a bit then an oil like interior vinyl treatment or armour-all can help bring it up but you'll have to re-apply it regularly or the fade spot will show up again when the treatment wears off.
Raw vinyl and matte trim are two big areas to avoid with a buff and wax in general, always tape them up. Some cars, especially SUVs have raw vinyl wheel arch flares and side skirt trims, staining these with waxes and buffing happens a lot because people don't tape them up. It's kind of a permanent result that you can only cover up with oil based treatments, but never actually remove without damaging the vinyl trim with solvent burns.
Oh yeah, FYI, solvents burn vinyl. Hence the window cleaner as always first resort, not a solvent. Next is a non-caustic degreaser like alkalai salts, diluted or prepsol but be very gentle with that.
