How to clean CLK500 Interior?
Was wondering, what do you guys use on leather seats and for cleaning interior of the car? Is Armor safe or no?
I just don't want to ruin interior of the car. Any advice would be greatly appreciated.
Interior: Griot's Garage interior cleaner (doesn't have a strong cleaner smell), Detailer's Pro Interior Protectant, soft make up brush. For areas like consoles where there are buttons, I simply use a wet microfiber cloth to wipe it clean. I try to stay away from products with chemicals because over time, it can fade out the letters on the buttons.
Leatherique for the leather. For the rejuvenator, it may be a little sticky afterwards but you need to create a 'sauna' inside with the windows rolled up to help the product cure and soak into the leather. I just leave it outside under the sun on a hot day. After that, the leather comes out really soft and smooth. If leather is still sticky, simply wipe off with the Prestine Clean.
Leatherique for the leather. For the rejuvenator, it may be a little sticky afterwards but you need to create a 'sauna' inside with the windows rolled up to help the product cure and soak into the leather. I just leave it outside under the sun on a hot day. After that, the leather comes out really soft and smooth. If leather is still sticky, simple wipe off with the Prestine Clean.
Thanks.
http://www.autogeek.net/leatherique-kit.html
Bob
This product is meant to help you clean and protect the interior. Use it on the dashboard, doors, console, navigation screens, arm rests, leatherette seats, vinyl trim and etc. The formula utilizes gentle cleaners that help you remove dust, dirt, oils, and much more from the interior. It also leaves behind a micro-barrier of protection from harmful ultra violet (UV) radiation.
It leaves the surface it’s applied to with an OEM matte finish. It uses no silicone and it's a water based formula doesn’t leave a sticky / oily residue behind. It has a very light citrus scent that makes using this product very pleasant. Mist it on the surface or directly on a damp microfiber towel and just wipe the desired surfaces.
Basic Three Step Leather Cleaning / Care - http://togwt1980.blogspot.co.uk/2015...ther-care.html
