Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
How-to De-badge my 99 E320
Old May 29, 2004 | 07:32 PM
extreme4377's Avatar
2006 Infiniti G35 Coupe
How can I do it without damaging anything? Will the paint underneath the letter/numbers be a different shade of black because it hasnt been exposed to the sun or anything else for years? Does it need to be professionally done?
Old May 29, 2004 | 09:32 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
To remove the E320..Use a piece of Fishing line/ weed edger line/Dental floss..to lift the letters then use a glue remover like 3m to clean up the glue left on the paint....
Then You MIGHT have a shadow from the letters depending how faded the paint is...TRY Rubbing compound to help
Old May 29, 2004 | 10:05 PM
thanks for the quick reply. If there is a shadow, can it be completely removed?
Old May 31, 2004 | 02:24 AM
Greg Elmassian's Avatar
2003 SL
A few comments:
Dental floss... fishing line and weed wacker line is too thick.
yes you may have a shadow, but the sun will probably fade it out with time.
I believe you have clear coat... grinding down the clear will likely do nothing except the rubbng compound will help prematurely wear out your clearcoat.
Greg
Old May 31, 2004 | 02:47 AM
I all ready de-baged my car. You can check out the pics in the E-class W210 section under the pictures thread. Thanks tho!
EDIT: I had a shadow but I waxed the area many times and it disappeared
Old Jun 9, 2004 | 01:19 PM
MikeyE430's Avatar
2010 E63 AMG, 2000 E430 Sport, Dodge Charger SRT8
WD-40 will help clean off any remaining adhesive.
Old Jun 9, 2004 | 01:32 PM
deuce zer0's Avatar
E63
i dont know about all that dental floss and wd-40. I did mine with a blow dryer. All you have to do is heat them badges up and just work them around with your fingers untill it comes off. then keep rubbing the extra glue while still heating and it comes off ez! I dont think you will have any real noticable if any fadding issues because it looks to me like all your vehicles are still new enough that the paint should still look great.
Old Jun 9, 2004 | 04:36 PM
thanks again for the help guys. I cant stop staring at my cars sexy, smooth ***
