Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Power Antenna & WD-40
Old Aug 3, 2004 | 12:23 PM
TX Charlie's Avatar
Question Power Antenna & WD-40
I spray a little WD-40 on a cloth and wipe it on my power antenna twice a year. I've never had any problems with this, but last week I was talking to the neighbor (corvette owner) who says he had never heard of doing this and thought it was completely unecessary. Anybody out there have any opinions on using WD-40 to keep the power antenna in good condition?
Old Aug 3, 2004 | 02:28 PM
Mortenstein's Avatar
E-220CDI, VW Multivan 2.5TDI
I clean the antenna of my remote control with WD-40... not a power antenna though
Old Aug 4, 2004 | 10:12 AM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
I’ve used WD (Water Deterrent) 40 on multiple makes / model year of vehicle antennae’s both power and manual without any problems. It provides lubricant and will not allow moisture to penetrate causing corrosion
~Hope this helps~
Old Aug 5, 2004 | 12:19 PM
Sam 325i's Avatar
Turbo Diesel
I clean my power antenna with WD40 and then EasyLube it so it goes up and down perfectly.
I've been doing it forever.
You're safe.
Old Aug 7, 2004 | 03:54 AM
X-Man's Avatar
CLK 430 / E 500
~Hope this helps~
WD (Water Displacement) 40 is great stuff... i used it on my corvette (and other cars) antenna every once in a while w/o problems. your neighbor is fortunate he's never had problems w/ moisture, dirt, and other crap accumlating in the mast and causing problems. cleaning the mast is one thing... keeping the mast clean and protected is another... whatever works, right?
Old Aug 8, 2004 | 10:53 AM
TX Charlie's Avatar
WD-40 and EasyLube
Thanks for all the responses! I'll keep using the WD-40 and I think I'll also give the EasyLube a try. I've been using WD-40 since I was a teenager. I was copying my grandpa who used to rub graphite oil on the metal moving parts of his cars. I've never seen graphite oil for sale anywhere though, so I figured WD-40 would work.
Old Aug 8, 2004 | 11:46 PM
Greg Elmassian's Avatar
2003 SL
I'd use Spray siliion, better Lubrication not greasy.
wd 40 is Spray kerosene - gets gummy after a while
Greg
