Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Window scratches
Old Nov 8, 2004 | 11:29 PM
J.G.'s Avatar
2000 E320 AWD
Window scratches
Does anyone have advice on how to remove minor scratches from the front window on my 2000 E320. Looks like maybe from ice scraper. John
Old Nov 9, 2004 | 11:00 AM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
~One man’s opinion / observations~
Polishing Glass Surfaces:
Methodology:
·Clean glass to remove dirt, dust or road grime from surfaces (also see note 1)
·Apply a quarter size amount of Autoglym Car Glass Polish™ or Iz Einzette Glas Polish to a damp cutting / polishing foam pad (LC Orange or White) attached to a Porter Cable random orbital buffer set at speed # 4.
·Apply to half of the windshield, polishing first in an up and down motion then in a left-to-right motion and then repeat on the other side, proceed to other glass surfaces.
·Go over the glass several times in each direction, glass will polish virtually residue free.
·Wipe off any residue, and polish with a clean dry 100% cotton Micro fibre cloth.
·Inspect glass for clarity and smoothness. Repeat if necessary.
Notes:
1.Do not use abrasive glass polish on after market-tinted glass or you will probably scratch the surface
2.For deeply etched water spots' or pits (caused by sand or road stones) in the glass surface, do not attempt to polish them out, consult an automotive glass vendor as glass used on later model cars is soft and thin (this may vary by manufacturer) due to weight / cost savings by vehicle manufactures and polishing could cause glass to crack.
Some windshields and mirrors have a tinted plastic coating or a blue tint that will scratch or be damaged, only polish or use synthetic wool on uncoated glass.
~Hope this helps~
Knowledge unshared is experience wasted [each one / teach one]
justadumbarchitect / so I question everything/ JonM
