Engine mounts
Old Dec 4, 2005 | 08:12 AM
Parrot of Doom's Avatar
W210 E300DT Saloon
Engine mounts
Just wondered, being relatively new to the marque, how much vibration is to be expected at idle speeds on a W210 E300 DT? The steering wheel has a slight vibration, but at 165k miles I was wondering if from new, the car had zero vibration? I'm thinking of changing the engine mounts.
Old Dec 5, 2005 | 12:22 AM
Benzalot's Avatar
2001 E430 Designo Edition, 2002 C230K Sport Coupe & 2006 C230 SS
Motor Mounts
Change them and you will be amazed at the difference. The mounts have a jell inside that goes away with age and the engine then transmits the vibration directly to the cabin. It is a fairly inexpensive fix.
Old Dec 5, 2005 | 12:31 PM
W210 E300DT Saloon
Thanks. The vibration is very small, you can't really see the steering wheel moving visually, just when you hold it it moves slightly.
Just wondered how much they vibrated with perfect mounts?
Old Dec 5, 2005 | 12:41 PM
maqsood's Avatar
How much are we talking about? I have a 2002 C230K and I feel the slight vibration as well.
TIA
Old Dec 6, 2005 | 12:07 AM
Benzalot's Avatar
motor mounts
It will get progressivly worse to the point where you can see your dash vibrate. With new mounts you will not feel anything. With the high
compression of the diesel, it can get pretty bad.
Old Dec 6, 2005 | 03:45 AM
EClassBenz's Avatar
E500
My E300 is shaking vigorously-especially on reverse for some reason It definitely needs new motor mounts. I will have them changed once I get back from Atlanta this weekend. (My car has 185k now-over 55k in the past year)
Old Dec 6, 2005 | 10:08 AM
W210 E300DT Saloon
Well mine isn't anywhere near that bad, so I think I'll leave it for now
