She has finally arrived
She needs a bit more TLC than I first anticipated. I had to get 2 tires and new wipers just to make her roadworthy, over and above the quart of oil and 1/2 a gallon of coolant.
Mechanically it is like new. Ran as a MB diesel should. Overall I'm very impressed with the car though.
But I do have some gremlins to work out. First is the trip odometer reset/dash light dimmer knob combo. The dash lights don't work and the odometer works when it wants to (unless you hold light pressure on it).
Hopefully they won't be too hard to find or replace.Next is the non-existant A/C compressor. They said it "fell off one day" and have lost track of it. Strangely the condenser is also missing.
No doubt the work of those pesky Germans that don't tighten all the bolts.
Or maybe it was built on a friday afternoon...
The syncros for 2nd gear are shot, as it scratches often when you shift. I'm thinking about a 5-speed that would swap in, as it sounds like it could use another gear at road speed.
With the exception of the headliner drooping by the back window, the interior is like new. The driver's seat has a couple of cracks, but no tears. I cleaned it up a bit today and I think the dirt/grime was helping to preserve it.
But overall I am in love. Simply a wonderful car.
What's the best method(s) and product(s) for cleaning and preserving the leather and other interior surfaces?
Dash lights: I've upgraded the entire cluster on my GF's car to LEDs. The only one that is a pain is the Fasten Seat Belts Light. It stays on very dimly due to bleed current through the cluster "IC" board. My advice there is just to clean it and use stock bulbs. The LEDs that I've used do make the cluster whiter though.
A/C: Oh what joys there are with A/C. Not difficult to work with, just stinking expensive.
Transmission: I've swapped the 4-speed in my GF's 240D with another used 4-speed. For a 5-speed conversion, I believe you will need the 5-speed out of a 280SL along with the front axle shaft, and the shift mechanism with all linkage. The 5th gear is kind of like an overdrive unit on the tail of the tranny from what I've seen. We've found that the 4-speed is great for 60-65mph, but the car gets considerably louder for 70-90mph.
Josh
Josh
