First Oil Change on 2007 ML320 CDI
Old Dec 15, 2006 | 12:56 PM
medici78's Avatar
'03 G500, '13 G63, '17 GLS63,
I was wondering what would be a recommended mileage/time to do the oil change on our new ML320 CDI. The dealer is saying to bringi it in whenever the computer says, which can be 10k miles. What would you folks with more diesel experience recommend?
Old Dec 15, 2006 | 02:10 PM
uberwgn's Avatar
e300d
when you're running the correct oil, it's fine to defer to the computer for change intervals.
Old Dec 15, 2006 | 05:00 PM
Green E-300 DT's Avatar
Late Built 2005 W-211 E-320 CDI
Talking To Each His Own . . .
If it were mine, I'd change the oil out the first time earlier than what the computer says.
Why?
I believe that no matter how foreign matter may get into the engine, the sooner it is removed, the better.
There may be debris left over from the original castings, etc.
To my way of thinking, why not play it safe and get rid of that debris that may be left inside?
Also, during the first 1000 miles, there will be minute metal shavings created during the break-in process.
After you change it that first time, then go with your changes when
the computer says, and continue with the computer schedule.
Old Dec 15, 2006 | 06:10 PM
lkchris's Avatar
'10 CL550, '12 GL550
Do it the way Mercedes specifies.
If you think they're wrong, why did you buy a Mercedes?
Old Dec 15, 2006 | 09:32 PM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
I always change oil and filter at 1,000 miles, 5,000 miles and every 5,000 miles thereafter. I plan to do the same with my ML320 CDI which will be delivered next week.
My engines have never used oil - even after 100,000+ miles on the clock. If it works, don't fix it!
Old Dec 17, 2006 | 07:39 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
what oil for your CDi?
What are the factory specifications for the ML 320 CDi?
Did they say synthetic? If so what grade? Old diesels use 15W40 or higher. I used gravel truck grades, non-synthetic, in my VW TDi. Worked great.
Old Dec 17, 2006 | 07:44 PM
harkgar's Avatar
Ken,
Oil changes are a cheap insurance policies particularly if non-synthetic grades are OK. If you have a MB diesel regular 5,000 mile oil changes are a must. A lot of car makers recommend lower grade synthetics I think due to fuel economy reasons rather than long term engine protection.
Old Dec 17, 2006 | 07:50 PM
DUTCH's Avatar
From the MBUSA website for the ML320 CDI:
The Mercedes-Benz Maintenance System We've made caring for your vehicle easier than ever. With the Mercedes-Benz Maintenance System, the service intervals are fixed and predictable - every 13,000 miles or one year (10,000 miles or one year for AMG models).*2* Your vehicle will even remind you about one month before service is due via an automatic display on the dashboard that also tells you which type of maintenance service is due.
*2*. Whichever comes first. Requires use of 229.5-spec oil and high-performance fleece oil filter. Driver is responsible for monitoring fluid levels and tire pressure between service visits. See Maintenance Booklet for details.
You can see the oils approved by MB Spec Sheet here:
http://www.whnet.com/4x4/oil.html
Old Dec 17, 2006 | 08:29 PM
DUTCH's Avatar
A perfect example of the error in this argument is the 5-speed auto transmission. "Sealed and no service for life" was MB's stand on this transmission.
Seems that "life" ended just after the warranty expired; and there were quite a few young (in life's terms) transmission failures. They have since changed their stand; and now recommend regular fluid and filter changes.
As someone else has already mentioned, regular oil (and fluid) changes are very inexpensive "life" insurance.
(I take delivery of mine tomorrow (12/18).
Old Dec 18, 2006 | 03:48 AM
khaug's Avatar
'05 E320 CDI, '07 VW Touareg V10 TDI, 2007 Porsche GT3
This is a very personal response, but I've decided to change my oil at 6K mile intervals. My decision is loosely based on oil analysis results.
Your Factory Approved Service Products booklet identifies motor oils which meet M-B requirements for your car. The short answer is Mobil 1 0w-40 synthetic, which is readily available here in Lansing, MI. There are other products on the list, but I've never found any of them on local retailer's shelves.
No doubt you'll get responses suggesting Mobil Delvac diesel motor oil. Delvac is NOT on the M-B approved list, and good though it may be, I'd avoid it for that reason. If you choose to use an unapproved oil, you're exposing yourself to possible denial of warranty claims.
Regards,
Old Dec 18, 2006 | 12:23 PM
Wolfgang's Avatar
MBs
Originally Posted by khaug
Your Factory Approved Service Products booklet identifies motor oils which meet M-B requirements for your car...
MBUSA recommends these two oils for 2007 ML320 CDIs:
Mobil 1 ESP Formula M 5W-40 (for MY07+ diesel)
Valvoline SynPower MST 5W-30 (for MY07+ diesel)
Old Dec 18, 2006 | 12:51 PM
uberwgn's Avatar
e300d
The ELF 229.51 oil is now available, too. It's a 5W30.
Old Dec 18, 2006 | 05:02 PM
DUTCH's Avatar
There are actually quite a few more that are on the approved list for Sheet 229.5, which is the minimum that must be met. Sheet 229.51 oils are also approved.
Old Dec 18, 2006 | 05:45 PM
Wolfgang's Avatar
MBs
MBUSA writes in their list of Factory Approved Service Products:
"As of model year 2007 diesel engines must only use 229.51 approved engine oil."
So far MBUSA put those two 229.51 oils on their recommended list.
Presumably one can also use any of the other 10 or so 229.51 oils like the ELF Solaris LSX 5W-30. And if no 229.51 oil is available substitute a good 229.5 oil, in particular those where the vapor pressure is similarly low, like Mobil1 0-W-40, so the particle filter doesn't get polluted...
Old Dec 18, 2006 | 06:18 PM
DUTCH's Avatar
Thanks for the correction. It's interesting that on their website MBUSA still shows 229.5 oils with a fleece filter as required to meet warranty.
Does this mean that the other oils shown on your oil page are not acceptable?
MB sheet 229.51 approved oils; low ash long life
Mercedes pioneered this new spec for passenger cars with diesel engines with EURO 4 or Bluetec exhaust particle filters and longer service life than the 229.31 oils. The spec was introduced in 2005. Change intervals increased to 20,000 kilometers. Based on ACEA A3 B4 and C3.
Amsoil European Car Formula 5W-40
Aral SuperTronic 229.51 0W-40 LOW SAPS
Castrol Longtec Turbodiesel 0W-30 (229.51)
Fuchs TITAN GT1 229.51 SAE 5W-30 (first fill oil in OM 642)
Mobil 1 ESP Formula M 5W-40 (to become available in the USA on 5/15/06)
Mobil 1 ESP Formula 5W-30 Emission System Protection (Europe, from 12/05)
Shell Helix Ultra AX 5W-30 Mercedes 229.51
Valvoline SynPower MST 5W-30 229.51 (added 6/1/2006)
Old Dec 18, 2006 | 07:04 PM
Wolfgang's Avatar
MBs
They are acceptable, but not MBUSA recommended so far, maybe because some are too new or only available outside of North America...
Old Dec 19, 2006 | 01:39 PM
DUTCH's Avatar
With regards to Mobil 1 ESP Formula M 5W-40 (to become available in the USA on 5/15/06), ExxonMobil says this oil is not available in the USA.
Old Dec 19, 2006 | 03:03 PM
Wolfgang's Avatar
MBs
Might not be generally sold yet as there are no 2007 passenger car diesels sold in the USA besides MBs.
But MB dealers should have it available by now. I've seen some reports where it was used already for oil changes, at P3.
Old Dec 19, 2006 | 05:03 PM
DUTCH's Avatar
ExxonMobil update is that it's available only at M-B dealers; and will probably be so for the foreseeable future.
Do you think there would be and warranty problems using another oil on the Sheet 229.51 list posted on your MB Oils website?
Old Dec 19, 2006 | 07:02 PM
Wolfgang's Avatar
MBs
229.51 oils should be fine. Might not be easy to find yet...
Just talked to Park Place. They have it only in bulk.
http://porsche.parkplacestores.com/mob1synoil.html
Old Dec 19, 2006 | 07:18 PM
DUTCH's Avatar
As much as I prefer Redline, they don't have anything approved; but Amsoil does.
In the mean time, I've contacted an MB dealer who sells discount parts to see if I can get a good price on the Mobil 1 stuff from him.
Old Dec 20, 2006 | 06:19 AM
DUTCH's Avatar
It doesn't appear that the oil on Park Place is the Mobil 1 ESP M 5W-40 (ExxonMobil's product name), as approved on Sheet 229.51. 229.51 oils are specific for the 2007+ diesel engines; and that oil at Park Place doesn't seem to be.
Old Dec 20, 2006 | 09:58 AM
Wolfgang's Avatar
MBs
Park Place has the Mobil 1 ESP Formula M 5W-40 only available in bulk, that means in a 55 gal drum and not in bottles. Since it is not available in bottles they do not sell it by mailorder like the other listed oils.
The correct name for this oil is Mobil 1 ESP Formula M 5W-40. Here is the spec sheet from their info site. (It's not error free...)
http://www.mobil.com/USA-English/Lub...la_M_5W-40.asp
There is also another Mobil 1 ESP Formula 5W-30 229.51 oil which is only available in Germany:
http://www.mobil.com/Germany-German/...mula_5W-30.asp
Old Dec 20, 2006 | 02:54 PM
DUTCH's Avatar
I found an MBUSA dealer in another state who has it in qt bottles - 6/case. However, he can't/won't ship as it falls in the HazMat category.
Luckily, I drive by that dealership when I travel to that state on business; so I can pick some up on my next trip. The other option was/is Amsoil; but during the initial warranty period I think it's probably prudent to use an oil that is in the MBUSA Maintenance Book.
Old Jan 15, 2007 | 12:30 PM
mercara's Avatar
99ml320
I used to own a 99ML320 (Gasoline not diesel). MB didn't recomment synthetic at first but a few engines started were hit with sludge build up after running on conventional oil for the computer recomended 10K + miles on conventional oil. About a year later, I received information from Mercedes in the mail saying that they had changed their policy to use only synthetic oil but that it was okay to go by the computer recomendation for oil change frequencies.
Personally I didnt feel comfortable with the computer numbers and did oil change with Mobil 1 synthetic 0-40 grade every 7500 miles.
