W210 Loud and Getting Louder
Old May 26, 2007 | 04:28 PM
frankfong's Avatar
My '97 W210 diesel engine is pretty loud...and seems to be getting louder. I detect that the engine is not running as smoothly anymore. Does anybody have a suggestion as to the cause and the fix? Could it be the grade of diesel (only #2) that I have been using? Maybe I am just getting older (turn down that noise! )
Thanks!
Old May 26, 2007 | 07:20 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Thanks!
What mileage?
How often do you change your oil?
Did you check the exhaust system? Hole in the muffler?
A 10 year old W210 diesel has a lot of life in it yet if taken care of.
Old May 28, 2007 | 04:15 PM
frankfong's Avatar
I have 168k on the engine and I change the oil about every 3000 miles. I don't think it is a problem with the muffler. That end of the car is pretty quiet. It is what is under the hood that is making all of the noise. I'm just wondering if it is extraordinarily loud.
Thanks!
Old May 29, 2007 | 09:12 AM
harkgar's Avatar
Thanks!
Did you use the right grade of oil? Maybe you should try the Castrol High Mileage 15W40 and see if it helps.
If you want to keep the car take it to a good mechanic or MB. It can be your hearing.
Old Jun 26, 2007 | 03:48 PM
michakaveli's Avatar
E300
Info you're providing is very vague. Could be a number of things... Narrow it dow to where in teh engine compartment it may be coming from. It's probably you're serpentine belt shock.
Old Jun 27, 2007 | 07:34 AM
Untertürkheim's Avatar
What type of sound is it? Knowing the type of oil you use would help. If it's Synthetic (M1 5w-40) or a high grade oil we can probably rule out lifters. Ever checked your timing chain (stretch, etc)? Injection timing, injectior pop test?
