ULSD question
ULSD question
I bought a used E320CDI (05) and originally it was run on what ever the pump had prior to ULSD. Now all the pumps in my area have ULSD (forget the MB site, it is way out of date).
Is there anything I should do to the car maintenance wise or can I continue as is with just regular maintenance. It has 55K and will be going in for a 60K sometime this fall I imagine.
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Freedom Diesels
Use LSD (500 ppm) as well as ULSD (50 ppm).
Use 5W40 synthetic engine oil (if you use anything other than MB specified low ash synthetics in the Bluetecs and newer diesel engines you are screwed)
In good old Ontario the only emission testing required for passenger diesel cars is visual. Visual means if your friendly tester is not looking deligently you pass. Every time.
These are freedom diesels. Keep your E320 CDi.
[url]http://www.pubmedcentral.nih.gov/articlerender.fcgi?artid=1570075{/url]
