Chip tuning?
Old Jul 18, 2007 | 02:40 PM
Ruud Bulterman's Avatar
MB C32 AMG
Chip tuning?
Diesel chip tuning van PSI idea????
Old Jul 18, 2007 | 10:03 PM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Huh? Can you say that more clearly/completely?
Old Jul 18, 2007 | 11:39 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
he is speaking Dutch
240 DT:
I know Pumpe Duese but not a PSI van.
Old Jul 19, 2007 | 12:16 AM
240D 3.0T's Avatar
I'm still trying to figure out what Diesel chip tuning van PSI idea is supposed to mean.
Diesel chip tuning, obvious.
van PSI idea, huh?
Old Jul 25, 2007 | 11:18 PM
harkgar's Avatar
van PSI idea, huh?
I see lots of pretty decent diesels on E-Bay at good prices. Is it advisable to buy ones without the turbo? There are a few 1998 and older 6 cylinder ones like that. Are they difficult to modify?
Old Jul 25, 2007 | 11:22 PM
240D 3.0T's Avatar
The non-turbo ones are good for economy but thats it. They aren't built for the extra stress of a turbo.
I just don't get what (drugs) was going through MB's R&D department for them to sell a non-turbo diesel car in the 90's.
Old Jul 25, 2007 | 11:23 PM
harkgar's Avatar
What is the difference?
Typically in Chevy and Ford aftermarket gasoline V-8 cars the way to get more power is to put in a new crankshaft and bore out the cylinders. I have never read about this method in diesel engines. Is there a good reason behind this? The stroking of a Chevy 350 to 383 is a good example.
There is no substitute for cubic inches.
Old Jul 26, 2007 | 01:12 AM
240D 3.0T's Avatar
Thats because there are no compatible engines to swap with.
About the only ones you could do that with is the early 200/220/240 engines.
Old Jul 26, 2007 | 10:50 PM
harkgar's Avatar
I thought it was due to the practice of coating cylinder walls with liners (iron?) in newer MB diesels. Obviously the cylinder liners will be destroyed in the process of boring out the cylinders and a new MB crank will cost big bucks. Transplant as you suggested will be the simplest solution.
Old Jul 30, 2007 | 01:49 PM
uberwgn's Avatar
e300d
Chip Tuning!
Old Jul 30, 2007 | 05:37 PM
harkgar's Avatar
Originally Posted by uberwgn
I have read about your W210 on the other board.
Your car had the modified "socketed computer" that enables you to use several different chips but I still do not know if what you did can be repeated with the W211 computer.
Any comments?
Old Jul 31, 2007 | 12:14 PM
uberwgn's Avatar
e300d
Any comments?
On the newer (VW) diesels, he simply flashes thru the OBD port. No more socketing, that's labor intensive. The process takes all of 5 minutes.
I really haven't asked him what's available, if anything, for the newer (MBz) cars. I'll see him in Aug...will ask.
Old Jul 31, 2007 | 12:48 PM
harkgar's Avatar
Thanks.
I am quite satisfied with the power and torque of the standard E320 CDi though bigger and more are always better until economy suffers.
Highway driving is the best for a diesel car. Fast and cheap.
What is the torque-power numbers for your car?
Old Jul 31, 2007 | 06:05 PM
uberwgn's Avatar
e300d
well, he suggests a gain of 25 hp and 50 ft*lbs. I think those values are understated. My father's got a 1998 diesel...there's a night and day difference between his car and my car
We attempted to dyno a chipped 1998 last year, but had no luck. We couldn't get the traction control completely shut down
Old Jul 31, 2007 | 06:57 PM
harkgar's Avatar
thanks
It sounds so exciting. 226 horses and 419 pound foot.
These are V-8 numbers until recently. If economy is retained this is absolutely magnificient. Is your friend into reflashing or tuning box?
