210-606 glow plug relay location
1999 e300td
got code 0380 (glow plug/heater CKT A malfunction)
looking to check fuse if, and relay to validate their operation. before chasing
glow plugs resistance. I assume you have to remove the intake manifold to gain access to the harness. If not please notify.
"99" e300d 115,000 m.
thank you
thank you
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
It should be located on the left hand side, behind the headlamp or under the washerbottle.
You can check the glow plug resistance from the control module plug, the pin numbers correlate to the glow plug number.
Anything over 3ohms with a cold engine (not started for 6hrs+) should be considered dead, anything between 1.5-3 ohms would be suspect.
