Help...
Old May 30, 2008 | 07:47 PM
lisaleigh's Avatar
2005 SL55 AMG & 85' 300TD =-)
Help...
NEED HELP...
Climate Control on my 85' 300TD
Old May 31, 2008 | 05:26 AM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
It usually helps us help you when you tell us WHAT you need help with!
"Climate Control" is a very broad range of things that can be a possibility. Vacuum leaks? Constant heat? No heat? No A/C? Air only through defroster? What?
Old Jun 7, 2008 | 11:07 AM
lisaleigh's Avatar
Sorry pretty vague huh?
Sorry, I was in a rush and did not give any details. The a/c continues to go out, replaced fuses, even had it fixed at the shop a few times, but after a short time it goes out again. The blower works, just no cool air. If I refill the freon it works for a while. Is this a common problem with this car, I have had it for ever and this problem started about 3 yrs ago. Any help would be greatly appreciated, Thanks. Lisa~
Old Jun 7, 2008 | 02:31 PM
EdzBenz's Avatar
W210 W140
It sounds like you have a leak in your air conditioning system if you have to continue filling it with freon.
Most shops can check for a freon leak quite easily. I would start there.
