Shut off valve/solenoid
Old Jul 21, 2008 | 09:15 AM
silverhalide1's Avatar
Merc
I believe i need to replace my shut off valve. although i dont want to buy the part if i dont need to. am i able to tell if the one im using is broke/needs replacing or if im fine?
I had replaced my fuel filters and after when i went to fire up the car it only cranked. after doing extensive research and testing im assuming the shut off valve shut off the fuel line. Am i able to recock or not? i drive a 83 240d.
thanks, jeff
Old Jul 21, 2008 | 01:55 PM
TMAllison's Avatar
09' E320
Sounds like you lost your prime and have air in the fuel lines.
Did you pre-fill the cannister filter? Pump the manual primer pump 50-100 times?
If yes, then crack a fuel line at the IP and crank until fuel comes out, then tighten. Do the same to the other three and then see if it will start.
