97 e300 Oil leak Help!
I am new to the desiel so any help would be welcomed. Thanks
The EPC shows a oil seal there. The pin goes directly into the timing chain cover and is exposed to oil. Mine didnt have one and the Dealers have never seen one and cant order it.
If you get a allen key you can carefully try to snug it up using a wrench. The fan blades are NOT symmetrical, there are small openings AND large openings. Find the large one. If the allen key is much more than 2" long you have to pull the radiator cross member and loosen the horn bracket and pull the rad forward to get enough clearance. WIS tells you to remove the rad, fan, etc. etc.
