w210 e320 cdi light mods how much power?
w210 e320 cdi
I have just bought the above
the cat has been removed, a less restrictive exhaust has been put in and has been custom remmapped. It feels as quick or may be quicker than my old 260bhp 1.8t VW Passat.
it does 30 - 70mph in around 5 secs
how much power/torque is it putting out?
ummmmm, then open the computer box and look for stickers inside the lid or on the ECU? Or look for add on chips (KD, etc.) since you don't know which, if any, it actually has.
Why are you timing it from 30 to 70mph? Why not 0-60mph so you ahve a known metric for comparission?
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
What model year is your W210?
w210 e320 cdi
I'm from the UK. They imported into the UK The 320 cdi from 1999. I used 30 - 70 to compare it to my 1.8t (fwd 282lbft) as there is no special launch procedure from standstill.
The best way is to put on a dyno but before then I thought I might ask here first. I did email the company but they havent got back to me
With just a remap Its about 230 bhp ish with 370 - 400 lbft
with the decat and exhaust what can i expect?
Whats the maximum i can get from the gt2359 and specifically what else can i do to it to release more?
Thank you
its the 2002 model as seen from the number plate the CDI badge was taken off
Thank you
![](http://i233.photobucket.com/albums/ee118/urmmm/back.jpg)
Thank you
Thank you
The good side is in due to the small number of diesel cars in Ontario Canada (3%) the present emission test is visual. No black smoke and you pass. It is easy to modify your engines to the end point of no black smoke. Is it the same in the UK or do you have to be hooked up to a computer like gasoline cars at the time of your MOT?
