Need Help Replacing Glow Plugs in 2007 E320 Bluetech
2007 E320 bluetec, 2009 ML320 Bluetec
Glow plug light warning is on. Researched forum to find DIY replacing glow plugs but only found 2006 model DIY information with needing 30 minutes to do. My car 2007 bluetech with 53,500 miles. Just out of warranty. Is it simple procedure to locate and remove GP. Do I need to replace all 6 or just the bad one. Do you have illustrations in removing parts to get to the glow plugs. Thanks in advance
81 300sd, 83 300dT, F350, 250 diesel & 16 ft car trailer
get a volt ohm meter, check their continuity with wire detached, if no resistance then adios.
They are a resistor, should read so much in value.
If some of the GP is not working then morning cold start should be harder and a bit of knocking too as not all cyls are firing.
