W126 Power Steering Reservoir
Old Jun 2, 2010 | 07:43 PM
Shamrock W126's Avatar
1985 300SD 413K, 1998 ML320 245K
Question W126 Power Steering Reservoir
I suspect my power steering fluid is low. When I steer from straight to either side, I get a gentle vibrating rumble sound. When the steering wheel is turned back to straight, the sound goes away.
I have noticed a consistent leak around one of the hoses going to the steering box, and will replace the hose once it comes in on Friday. Till then, I was hoping to top off the fluid and get better (normal) steering performance.
Question is - how do you check the level, or know how 'full' to fill the reservoir? When I unscrew the black knob and remove the aluminum top, there is no dipstick or min/max markings.
Any ideas?
Shamrock W126
'85 300SD 413,865
'98 ML320 245,660
Old Jun 3, 2010 | 12:30 AM
blowfish's Avatar
81 300sd, 83 300dT, F350, 250 diesel & 16 ft car trailer
when u see lots of oil in there it should be Ok, if its low then u add.
