Amsoil is one of the ones the testing engineers at my wife's old job spoke highly of. It was the Amsoil oil itself the discussion with them was about and not any of their additives. With that said though I still run Delo 400 in the old 300SD we have here and I think it is around 215k miles and definitely no issues but given how many of those engines are out there running a LOT more miles than that then not sure oil selection tells me much on it specifically. I used to run Amsoil in the Ford 6.0 sitting here but ultimately switched back to Delo 400 and now days actually it is whatever the mechanic uses because I quit doing my own changes. My 6.0 has had a lot of injector failures but they are known for that problem so not sure if oil selection had anything to do with it. The 6.0 has 250k or so miles, for whatever that is worth and no engine issues to date outside the stupid injectors of course.
Quote:
First of all, diesel in NA is in range ~40 octane and in Europe ~ 55 (not expert but it could damage injectors on long run).
Power service is increasing octane value for ~8 and it brings to Europe octane value.
As for cleaning, I agree that current USLD is clean enough that you don't need extra cleaning but from time to time, you can get diesel from bottom of tank which it could include some dirt, water etc.
Also, a lot of additives are designed for OM642, bio-diesel engine and you have to check label before put in tank.
In my case, I see difference in power and engine work with Power Service additive - I put EVERY time around one glass when I fill tank ..
My 0.02 $ ...
I use a Cetane Improver as well. It typically runs around 45 in my market versus 55 in the EU.Originally Posted by zemun1234
I am using Power Service from Day one ...First of all, diesel in NA is in range ~40 octane and in Europe ~ 55 (not expert but it could damage injectors on long run).
My 0.02 $ ...
I had a 2005 F250 with 6.0 powerstroke that I purchased used in Nov '11 with 211,000 miles on it and regret not researching before buying it. It was almost impossible to start below 40 degrees F. and I traded it and a 2002 911 Porsche convertible for a big loss on both. Porsche was nickel dimeing me witth
only 43k miles as I only put 17k miles on it from purchase at a Porsche dealer as a CPO car. Another hard lesson learned. I bought a new 2012 F350 crew cab FX4 short bed w/ultimate lariet pkg in White Platinum Metallic and 6.7L powerstroke, 20" rims,etc and am very happy with it 13;500 miles later. I use 5W-40(DEO) synthetic oil in it with excellent results and cetane boost plus diesel fuel concentrate additives @ rate of 1oz. per 5 gal of fuel. I will do likewise with my S350 BlueTec after getting it home from Dallas,Tx.. I've used Amsoil since 1983 and I swear by their lubes and fuel additives as well as spin on filters that they make for my truck.
Engines with DPF's should use MB spec 229.51
229.51 Low SP Ash multigrade service engine oils (Specification 229.51)
For use in vehicles/engines refer to Sheet 223.2
Select Sheet 133.0137.1138.1225.0225.10225.11225.12225.14225.15 225.16225.17225.18225.21225.22225.26225.5225.6225. 8225.9226.9228.0228.1228.2228.3228.31228.5228.5122 9.1229.3229.31229.5229.51235.0235.1235.10235.11235 .12235.13235.15235.20235.27235.28235.29235.4235.41 235.5235.6235.61235.7235.71235.72235.74235.8235.92 36.1236.10236.11236.12236.13236.14236.15236.2236.2 0236.21236.25236.26236.3236.41236.6236.7236.8236.8 1236.9236.91261.0264.0265.1266.0266.2267.0267.1268 .0269.2310.1311.0312.0325.0325.2325.3325.5326.0326 .3326.5331.0331.1332.0341.0342.0343.0344.0345.0350 .0361.0361.1362.0362.1371.0382.0383.0385.1385.2385 .3385.4385.5
Overview
Last update: 09/20/2012
PRODUCTNAME
0W-30
0W-40
5W-30
5W-40
PRINCIPAL
MB 229.51 Erstbetriebs-Motorenöl A 001 989 05 01 x Daimler AG, Stuttgart/Deutschland
MB 229.51 Motorenöl A 000 989 97 01 x Daimler AG, Stuttgart/Deutschland
MB 229.51 Motorenöl A 001 989 06 01 x Daimler AG, Stuttgart/Deutschland
MB 229.51 Motorenöl A 001 989 16 01 x Daimler AG, Stuttgart/Deutschland
Mercedes-Benz 229.51 mit VW 504.00/507.00 x Daimler AG, Stuttgart/Deutschland
Mercedes-Benz Motorenoel MB 229.51 BlueTEC x Daimler AG, Stuttgart/Deutschland
Mercedes-Benz PKW-Synthetic Motorenöl MB 229.51 x Daimler AG, Stuttgart/Deutschland
77 MOTOR OIL LE 5W-30 x 77 Lubricants B.V. , DORDRECHT/THE NETHERLANDS
77 MOTOR OIL LE 5W-40 x 77 Lubricants B.V. , DORDRECHT/THE NETHERLANDS
8100 X-clean + 5W-30 x Motul , AUBERVILLIERS CEDEX/FRANCE
ad-High Tech 5W-30 Longlife III x CARAT Systementwicklungs- u. Marketing GmbH & Co. KG, Mannheim/Deutschland
ADAMOL MULTITOP Longlife 5W-30 x BP p.l.c., LONDON/UNITED KINGDOM
ADAMOL MULTITOP VSI x BP p.l.c., LONDON/UNITED KINGDOM
ADDINOL Giga light MV 0530 LL x Addinol Lube Oil GmbH, Leuna/Deutschland
ADNOC VOYAGER GOLD 5W/30 x Adnoc Distribution, Abu Dhabi/UNITED ARAB EMIRATES
ADVANT 5W-30 x Coastal Blending & Packaging, Saint John, NB/CANADA
ADVANT 5W-40 x Coastal Blending & Packaging, Saint John, NB/CANADA
Agip 7008 x ENI S.p.A. - Refining & Marketing Division, ROM/ITALY
AKRON SPITZEN x Mexicana de Lubricantes, S.A. de C.V., GUADALAJARA C.P. 44940/MEXICO
Alpine Longlife III 5W30 x Mitan Mineralöl GmbH, Ankum/Deutschland
ALPINE RSL 5W30 LA x Mitan Mineralöl GmbH, Ankum/Deutschland
ARAL HIGH TRONIC G SAE 5W-30 x Aral Aktiengesellschaft, Hamburg/Deutschland
ARAL SuperTronic x Aral Aktiengesellschaft, Hamburg/Deutschland
ARAL SuperTronic Diesel 0W-40 x Aral Aktiengesellschaft, Hamburg/Deutschland
ARAL SuperTronic LongLife III x Aral Aktiengesellschaft, Hamburg/Deutschland
AVIASYNTH LS 0W-40 x Avia Mineralöl-AG, München/Deutschland
AVIASYNTH LSP 5W-30 x Avia Mineralöl-AG, München/Deutschland
AVIASYNTH LSP PLUS 5W-30 x Avia Mineralöl-AG, München/Deutschland
biloxxi 5W-30III x MCC Trading Deutschland GmbH, Düsseldorf/Deutschland
Biloxxi 5W-40 HC x MCC Trading Deutschland GmbH, Düsseldorf/Deutschland
Bizol New Generation x Bita Trading GmbH, Berlin/Deutschland
Blasol PDLS 5W30 x Blaser Swisslube AG, Hasle-Rüegsau/Schweiz
BM1 Gold Series x PT Birumegah Abadi, Jakarta Barat/INDONESIA
bp Visco 5000 C 5W-40 x BP p.l.c., LONDON/UNITED KINGDOM
bp Visco 5000M x BP p.l.c., LONDON/UNITED KINGDOM
bp Visco 7000 0W-40 x BP p.l.c., LONDON/UNITED KINGDOM
bp Visco 7000 5W-30 x BP p.l.c., LONDON/UNITED KINGDOM
bp Visco 7000 C 5W-40 x BP p.l.c., LONDON/UNITED KINGDOM
Caltex Havoline Ultra S x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
Caltex Havoline Ultra V x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
Cartechnic Motorenöl SAE 5W-30 MS x Auto-Teile-Ring GmbH, Stuttgart/Deutschland
Cartechnic Motorenöl SAE 5W-30 Multi x Auto-Teile-Ring GmbH, Stuttgart/Deutschland
Castrol Edge 5W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE FST 0W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE FST 0W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE FST 5W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE Professional C3 0W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE Professional OE 5W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol EDGE PROFESSIONAL OE-X 5W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Edge Turbo Diesel 0W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Edge Turbo Diesel 5W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Magnatec Professional C3 5W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Magnatec Professional MP 5W-30 x Castrol Limited, SWINDON/UNITED KINGDOM
Castrol Magnatec Professional OE 5W-40 x Castrol Limited, SWINDON/UNITED KINGDOM
CENTRO Motoröl Longlife III x CENTRO Handelsgesellschaft mbh & Co. KG, Karlsruhe/Deutschland
CENTRO MOTORÖL SAE 5W-30 Spezial x CENTRO Handelsgesellschaft mbh & Co. KG, Karlsruhe/Deutschland
CEPSA Xtar 5W30 MEGA TECH DPF x Cepsa Lubricantes, S.A., MADRID/SPAIN
CLASSIC MEDUNA PT 530 LONGLIFE III LA x CLASSIC Schmierstoff GmbH & Co. KG, Hoya/Deutschland
COFRAN SINTOLUX FORCE 3 5W-30 x Fuchs Lubrifiants France, NANTERRE CEDEX/FRANCE
CONCEP-TECH DX SAE 5W30 x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
CONCEP-TECH Synth. x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
CYCLON F1 TDi x Cyclon Hellas S.A., ASPROPIRGOS/GREECE
DELKOL MOTORSYNTH TDI 5W-40 x Delek, NATANYA/ISRAEL
DENiCOL Long Drive m.s.t. 5W30 x Denicol Motor Oils NV, Ranst/BELGIUM
Divinol Syntholight DPF x Zeller+Gmelin GmbH & Co. KG, Eislingen/Deutschland
Divinol Syntholight HC-FE x Zeller+Gmelin GmbH & Co. KG, Eislingen/Deutschland
Elf Excellium C 3 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Elf Excellium TDI 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Elf Solaris LLX 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Elf Solaris LSX 5W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Elf Solaris MSX 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
eni i-Sint 5W-30 x Eni S.p.A., Refining & Marketing Division, ROME/ITALY
eni i-Sint MS 5W-30 x ENI S.p.A. - Refining & Marketing Division, ROM/ITALY
eni i-Sint MS 5W-40 x ENI S.p.A. - Refining & Marketing Division, ROM/ITALY
ENOC PROTEC GREEN 5W 40 x ENOC International Sales L.L.C., DUBAI/UNITED ARAB EMIRATES
Eurolub Cleantec 5W/30 x EUROLUB GmbH, Eching/Deutschland
EUROLUB WIV ECO 5W-30 x EUROLUB GmbH, Eching/Deutschland
EVOLUTION OEM Series IV 5W-40 x TOP 1 Oil Products, San Mateo, CA/USA
FENIX PREMIUM SAE 5W-30 x Fabrika maziva - FAM a.d., KRUSEVAC/SERBIA
Feu Vert MULTI NORMES 5W40 x Feu Vert, ECULLY CEDEX/FRANCE
Fina First 500 504/507 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Fina First 500 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Fosser Premium LA 5W30 x Mitan Mineralöl GmbH, Ankum/Deutschland
Fuchs TITAN GT1 PRO C-3 SAE 5W-30 x Fuchs Petrolub AG, Mannheim/Deutschland
FULL BORE Fully Synthetic Motor Oil 5W-30 x Tay Ruenn Enterprise Co., Ltd, Taoyuan Hsine/TAIWAN
FULL BORE Fully Synthetic Motor Oil 5W-40 x Tay Ruenn Enterprise Co., Ltd, Taoyuan Hsine/TAIWAN
G-Energy Service Line GMO 5W-30 x Gazpromneft-Lubricants LTD, MOSCOW/RUSSIA
G-Energy Service Line W 5W-30 x Gazpromneft-Lubricants LTD, MOSCOW/RUSSIA
G-Energy Service Line W 5W-40 x Gazpromneft-Lubricants LTD, MOSCOW/RUSSIA
GALP Active 3000 M-LS 5W30 x Petrogal S.A., LISSABON/PORTUGAL
Galp Energy Ultra LS x Petrogal S.A., LISSABON/PORTUGAL
GALP Fórmula longlife III x Petrogal S.A., LISSABON/PORTUGAL
GECCO 5W-30 Motorenöl MZB x Zeus, Zentrale für Einkauf und Service GmbH & Co.KG, SOLTAU/Deutschland
GECCO 5W-40 Motorenöl SY x Zeus, Zentrale für Einkauf und Service GmbH & Co.KG, SOLTAU/Deutschland
Gulf Formula GVT x Gulf Oil International, London/ENGLAND
Gulf FORMULA ULE x x Gulf Oil International, London/ENGLAND
Gulf Progress Efficiency 5W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Gulf Progress Extended 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Havoline Ultra S x x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
HEM Longlife III x Deutsche Tamoil GmbH, Elmshorn/Deutschland
IGOL PROFIVE DIAMANT x Igol France, AMIENS CEDEX/FRANCE
IGOL PROFIVE EMERAUDE x Igol France, AMIENS CEDEX/FRANCE
IGOL PROFIVE GOLD 5W-40 x Igol France, AMIENS CEDEX/FRANCE
IGOL PROFIVE PLATINIUM 5W-30 x Igol France, AMIENS CEDEX/FRANCE
INA Star x INA Rafinerija nafte Rijeka, RIJEKA/CROATIA
K-Classic Motorenöl 5W30 LA x Kaufland Warenhandel GmbH & Co. KG, Neckarsulm/Deutschland
K-Classic Motorenöl 5W30 Longlife III x Kaufland Warenhandel GmbH & Co. KG, Neckarsulm/Deutschland
KA NASA KEN TURBO DIESEL DPF C3 5W-30 x Power International Chemical & Oil Corp, YAMAGUCHI-KEN/JAPAN
Kixx PAO 5W/30 x GS-Caltex Corporation, SEOUL/Rep. of KOREA
Kixx PAO 5W/40 x GS-Caltex Corporation, SEOUL/Rep. of KOREA
Kuttenkeuler Sorotec 2 + PDi 5W-40 x Kuttenkeuler GmbH, Köln/Deutschland
LazerWay LL 5W-30 x Svenska Statoil AB, STOCKHOLM/SWEDEN
LIQUI MOLY 5W-30 TOP TEC 4200 x Liqui Moly GmbH, Ulm/Deutschland
LIQUI MOLY 5W-30 TOP TEC 4605 x Liqui Moly GmbH, Ulm/Deutschland
LIQUI MOLY Pro-Engine M 500 x Liqui Moly GmbH, Ulm/Deutschland
LIQUI MOLY Top Tec 4600 x Liqui Moly GmbH, Ulm/Deutschland
LONGLIFE ULTRA SP 1 x Müller Mineralöle GmbH & Co. KG , Eschweiler/Deutschland
LOTOS quazar 5W40 x Grupa Lotos SA., GDANSK/POLAND
LOTOS quazar C3 5W30 x Grupa Lotos SA., GDANSK/POLAND
LOTOS quazar LLIII 5W30 x Grupa Lotos SA., GDANSK/POLAND
LUBREX, SM/CF 5W-30 x LUBREX FZC, SHARJAH/UNITED ARAB EMIRATES
LUKOIL GENESIS Premium 5W-30 x OOO LLK-International, MOSCOW/RUSSIA
LUKOIL GENESIS Premium 5W-40 x OOO LLK-International, MOSCOW/RUSSIA
M-Tronic Extra x Kuttenkeuler GmbH, Köln/Deutschland
mabanol Xenon Alpha LA 5W-30 x Mabanol GmbH & Co. KG, Hamburg/Deutschland
mabanol Xenon Ultra Synth Longlife 5W-30 x Mabanol GmbH & Co. KG, Hamburg/Deutschland
master oil c-tec Power 5W-30 LL3 x Interparts Autoteile GmbH, Stuttgart/Deutschland
MatraX InfluX 5W30 DPF/C3 x Industrial Química Riojana, S.A., PRADEJÒN - La Rioja/SPAIN
MatraX InfluX 5W40 505.01 x Industrial Química Riojana, S.A., PRADEJÒN - La Rioja/SPAIN
Max Raloy Service 229.51 x Raloy Lubricantes, S.A. de C.V., Santiago Tianguistenco/MEXICO
maxima GA 5W-30 x Petrol Ofisi Anonim Sirketi, Istanbul/TURKEY
MEGA STAR SAE 5W-30 x Addinol Lube Oil GmbH, Leuna/Deutschland
megol Motorenoel Compatible x Meguin GmbH & Co. KG Mineraloelwerke, Saarlouis/Deutschland
megol Motorenoel Efficiency x Meguin GmbH & Co. KG Mineraloelwerke, Saarlouis/Deutschland
megol Motorenoel New Generation x Meguin GmbH & Co. KG Mineraloelwerke, Saarlouis/Deutschland
Meisteröl WIV 5W-30 Longlife x EPRO GmbH, Ulm/Deutschland
Midland crypto 3 5W-30 x Oel-Brack AG, HUNZENSCHWIL/Schweiz
MIDLAND synova 5W-30 x Oel-Brack AG, HUNZENSCHWIL/Schweiz
Midland synova 5W-40 x Oel-Brack AG, HUNZENSCHWIL/Schweiz
Mobil 1 ESP 0W-30 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil 1 ESP 0W-40 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil 1 ESP Formula 5W-30 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil 1 ESP Formula M 5W-40 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil Super 3000 XE 5W-30 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Mobil Syst S Special V 5W-30 x Exxon Mobil Corporation, FAIRFAX, Virginia/USA
MOGUL 5W-30 Professional LF III x Paramo, a.s., PARDUBICE/CZECH REPUBLIC
MOGUL 5W-40 PROFESSIONAL x Paramo, a.s., PARDUBICE/CZECH REPUBLIC
MOL Dynamic Gold 5W-30 x MOL-LUB Ltd., ALMÀSFÜZITÖ/HUNGARY
MOL Dynamic Prima 5W40 x MOL-LUB Ltd., ALMÀSFÜZITÖ/HUNGARY
Motor Oil LE 5W-30 x Transnational Blenders B.V., BG DORDRECHT/THE NETHERLANDS
Motor Oil LE 5W-40 x Transnational Blenders B.V., BG DORDRECHT/THE NETHERLANDS
Motor Oil Longlife-III Synthetic 5W-30 x Transnational Blenders B.V., BG DORDRECHT/THE NETHERLANDS
MOTOR OIL VX 5W-30 x 77 Lubricants B.V. , DORDRECHT/THE NETHERLANDS
MOTOREX PROFILE V-XL SAE 5W/30 x Bucher AG Langenthal, LANGENTHAL/Schweiz
MOTOREX SELECT LA-X x Bucher AG Langenthal, LANGENTHAL/Schweiz
MOTOREX SELECT SP-X 5W/30 x Bucher AG Langenthal, LANGENTHAL/Schweiz
MOTUL 8100 X-CLEAN 5W-30 x Motul , AUBERVILLIERS CEDEX/FRANCE
Motul 8100 X-clean 5W-40 x Motul , AUBERVILLIERS CEDEX/FRANCE
MOTUL EXPERT LL 5W-30 x Motul , AUBERVILLIERS CEDEX/FRANCE
Motul Specific 229.51 5W-30 x Motul , AUBERVILLIERS CEDEX/FRANCE
MPM 05000 DPF Motoroil 5W-30 x MPM International Oil Company B.V., HN DELFT/THE NETHERLANDS
Nordlub V-DX x NORDLUB Deutschland GmbH, Buxtehude/Deutschland
Nordlub V-Kombi LL3 SAE 5W-30 x NORDLUB Deutschland GmbH, Buxtehude/Deutschland
Nordlub V-PD x NORDLUB Deutschland GmbH, Buxtehude/Deutschland
NORTHLAND EUROSYN SAE 5W40 x Northland Products Company, WATERLOO, IOWA/USA
OEST GIGANT LS PLUS SAE 5W-30 x Georg Oest Mineralölwerk GmbH & Co KG, Freudenstadt/Deutschland
Oilfino Via Ultra LL 5W-30 x Carl Harms Mineralöle, Prisdorf/Deutschland
OMV BIXXOL special C3 SAE 5W-30 x OMV Refining & Marketing GmbH, VIENNA/Österreich
OMV BIXXOL special UP SAE 5W-30 x OMV Refining & Marketing GmbH, VIENNA/Österreich
OPALJET ENERGY 3 x Unil Opal, SAUMUR/FRANCE
OPALJET LONGLIFE 3 x Unil Opal, SAUMUR/FRANCE
Panolin Avanis C3 x PANOLIN AG, MADETSWIL/Schweiz
PANOLIN AVANIS SV-X x PANOLIN AG, MADETSWIL/Schweiz
PANOLIN DAYTONA LA x PANOLIN AG, MADETSWIL/Schweiz
Pennzoil Platinum VX x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
Pennzoil Ultra Euro L x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
PENRITE ENVIRO+ 5W-30 x Penrite Oil Company Pty Ltd, WANTIRNA SOUTH/AUSTRALIA
PENRITE ENVIRO+ 5W-40 x Penrite Oil Company Pty Ltd, WANTIRNA SOUTH/AUSTRALIA
Pento High Performance II 5W-40 x Deutsche Pentosin-Werke GmbH, Wedel/Deutschland
Pento Super Performance III 5W-30 x Deutsche Pentosin-Werke GmbH, Wedel/Deutschland
PENTOSYNTH HC x Deutsche Pentosin-Werke GmbH, Wedel/Deutschland
PERTAMINA Fastron GOLD x PERTAMINA , Jakarta/INDONESIA
Power Oil High-Tech Super Combi 5W30 x Power Oil e.K., Karlsfeld/Deutschland
PRAKTIKER SAE 5W-30 x Addinol Lube Oil GmbH, Leuna/Deutschland
Presteza MSP 5W-30 x Kroon Oil B.V., EC ALMELO/THE NETHERLANDS
Prista Ultra Plus x Prista Oil Holding EAD, Ruse/BULGARIA
Q Diesel Plus x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
Q8 FORMULA M LONG LIFE 5W-40 x Kuwait National Petroleum Company, Kuwait/KUWAIT
Q8 FORMULA SPECIAL G LONG LIFE 5W-30 x Kuwait Petroleum, ROZENBURG/THE NETHERLANDS
Q8 Formula V Long Life SAE 5W-30 x Kuwait Petroleum, ROZENBURG/THE NETHERLANDS
Q8 Formula VX Long Life SAE 5W-30 x Kuwait Petroleum, ROZENBURG/THE NETHERLANDS
QS Q Diesel Plus x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
QS Ultimate Durability European L x Pennzoil-Quaker State, HOUSTON, TEXAS 77002/USA
RAVENOL VMP SAE 5W-30 x Ravensberger Schmierstoffvertrieb GmbH, Werther/Deutschland
real,- Quality GPD 5W-40 x real,- Handels GmbH, Düsseldorf/Deutschland
real,- Quality GSL 5W-30 x real,- Handels GmbH, Düsseldorf/Deutschland
REPSOL ELITE Evolution Long Life 5W30 x Repsol YPF Lubricantes y Especialidades, S.A., MOSTOLES - MADRID/SPAIN
REPSOL ELITE Long Life 50700/50400 x Repsol YPF Lubricantes y Especialidades, S.A., MOSTOLES - MADRID/SPAIN
ROWE MULTI SYNT DPF 5W-30 x ROWE Mineralölwerk GmbH, Bubenheim/Deutschland
SELÈNIA MOTOR OIL PURE ENERGY K 5W-40 x PETRONAS LUBRICANTS INTERNATIONAL, KUALA LAMPUR/MALAYSIA
Shell Helix Diesel Ultra AB-L x x x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Diesel Ultra Extra x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra AB-L x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra AM-L x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra AX x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra Extra x x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell Helix Ultra Extra X x Shell International Petroleum Company, LONDON/UNITED KINGDOM
Sinopec Justar J600-E x Lubricant Company, Sinopec Corp., Beijing/P. R. of CHINA
SONOL SYNT 505.01 x Sonol Israel Ltd., NETANYA/ISRAEL
Specialsynth Gold 5W30 x PHI OIL GmbH, St. Georgen bei Salzburg/Österreich
Specialsynth gold 5W40 x PHI OIL GmbH, St. Georgen bei Salzburg/Österreich
Specialsynth MSP 5W40 x Kroon Oil B.V., EC ALMELO/THE NETHERLANDS
SRS ViVA 1 SLV plus x SRS Schmierstoff Vertrieb GmbH, Salzbergen/Deutschland
SRS ViVA 1 topsynth alpha LA x SRS Schmierstoff Vertrieb GmbH, Salzbergen/Deutschland
SSU EURO XT PLUS x x S-OIL, Seoul/Rep. of KOREA
Startol Synt 2 + PDI 5W-40 x Müller Mineralöle GmbH & Co. KG , Eschweiler/Deutschland
Statoil LAZERWAY G 5W-30 x Svenska Statoil AB, STOCKHOLM/SWEDEN
SUNOCO SYNTURO XENON 5W30 x Petronas Lubricants Belgium NV, Aartselaar/BELGIUM
SUNOCO SYNTURO XENON 5W40 x Petronas Lubricants Belgium NV, Aartselaar/BELGIUM
swd Rheinol Primus DX 5W30 x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
Swd Rheinol Primus DXM SAE 5W-40 x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
Swd Rheinol Primus LLX SAE 5W-30 x Swd Lubricants GmbH & Co. KG, Duisburg/Deutschland
SynPower XL-III x The Valvoline Company, LEXINGTON, KY/USA
SynPulsar-N x Bardahl Asia Pacific Pte Ltd, SINGAPUR/SINGAPUR
SYNTIUM 3000 AV x PETRONAS LUBRICANTS INTERNATIONAL, KUALA LAMPUR/MALAYSIA
SYNTIUM 5000 AV x PETRONAS LUBRICANTS INTERNATIONAL, KUALA LAMPUR/MALAYSIA
TAMOIL SINT FUTURE ENERGY x Tamoil Italia S.p.A., MILANO/ITALY
TEBOIL DIAMOND DIESEL SAE 5W-40 x LLK Finland Oy, Oy Teboil Ab, HAMINA/FINLAND
TECAR Special DX2 Motorenöl 5W-30 x Techno - Einkauf GmbH, Norderstedt/Deutschland
TECTROL SPEED LL 530 x BayWa AG, München/Deutschland
Tedex Synthetic Premium Motor Oil x Tedex S.A., Piaseczno/POLAND
Texaco Havoline Ultra V x Chevron Global Lubricants, GENT/ZWIJNAARDE/BELGIUM
TITAN GT1 PRO FLEX 5W-30 x Fuchs Petrolub AG, Mannheim/Deutschland
TITAN GT1 PRO GAS 5W-30 x Fuchs Petrolub AG, Mannheim/Deutschland
TNK Magnum Professional C3 5W-30 x TNK Lubricants, LLC, MOSCOW/RUSSIA
TNK Magnum Professional C3 5W-40 x TNK Lubricants, LLC, MOSCOW/RUSSIA
TNK Magnum Professional C3 LL x TNK Lubricants, LLC, MOSCOW/RUSSIA
Top Paz 5w-40 x Paz Lubricants & Chemicals Ltd., HAIFA 31000/ISRAEL
Tor Extendo NF 5W30 x De Oliebron, ZWIJNDRECHT/THE NETHERLANDS
Tor Specialsynth 5W40 NF x De Oliebron, ZWIJNDRECHT/THE NETHERLANDS
Tor Specialsynth NF 5W30 x De Oliebron, ZWIJNDRECHT/THE NETHERLANDS
Total Activa Ineo Long Life 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz Ineo Long Life 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz INEO MC3 5W-30 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Total Quartz INEO MC3 5W-40 x Total Lubrifiants, PARIS la Defense Cedex/FRANCE
Triathlon Endurance III x Adolf Würth GmbH & Co. KG, Künzelsau/Deutschland
Ultra Tronic x Kuttenkeuler GmbH, Köln/Deutschland
Valvoline SYNPower MST 5W-40 Full Synthetic x The Valvoline Company, LEXINGTON, KY/USA
Valvoline SYNPOWER MST SAE 5W-30 x The Valvoline Company, LEXINGTON, KY/USA
Velox ULTRA SX SAE 5w-30 x Aeagean Oil S.A., ATHENS/GREECE
VITA EXTRA x Müller Mineralöle GmbH & Co. KG , Eschweiler/Deutschland
VOLTRONIC 5W30 MDPF Motoröl x Voltronic & ACT GmbH, Bad Boll/Deutschland
WAVE POWER LE 5W-30 x North Sea Lubricants B.V., LV ALPHEN aan den RIJN/THE NETHERLANDS
WAVE POWER LE 5W-40 x North Sea Lubricants B.V., LV ALPHEN aan den RIJN/THE NETHERLANDS
WAVE POWER LL 5W-30 x North Sea Lubricants B.V., LV ALPHEN aan den RIJN/THE NETHERLANDS
WOLF MASTERLUBE SYNFLOW C3 5W30 x Wolf Oil Corporation N.V., HEMIKSEN/BELGIUM
WOLF OFFICIALTECH 5W30 C3 x Wolf Oil Corporation N.V., HEMIKSEN/BELGIUM
WOLF OFFICIALTECH 5W30 LL III x Wolf Oil Corporation N.V., HEMIKSEN/BELGIUM
XF LONG LIFE C3 5w30 x Millers Oils Lt., BRIGHOUSE WEST YORKSHIRE/UNITED KINGDOM
YACCO LUBE DE SAE 5W-30 x Yacco SAS, ST PIERRE LES ELBEUF/FRANCE
YACCO VX 1703 5W-30 x Yacco SAS, ST PIERRE LES ELBEUF/FRANCE
YORK 948 x Ginouves Georges SAS, TOULON /FRANCE
ZIC A+ 5W-30 x SK Lubricants, DAEJEON/Rep. of KOREA
ZIC XQ LS 5W-30 x SK Lubricants, DAEJEON/Rep. of KOREA
ZIC XQ RV 5W-40 x SK Lubricants, DAEJEON/Rep. of KOREA
Overview
PRODUCTNAME
0W-30
0W-40
5W-30
5W-40
PRINCIPAL
I need to clarify what motor oil I will use in the S350 BlueTec and it is a 5W-40 European Formula that is low SAPS and MB 229.51 specificaton. I actually have been using this very same oil in my '98 S320V for over 60,000 miles now and the odometer reads over 187,000 as I bought the car used 12-07. I use a gasoline additive in it called P.I. from Amsoil and only a 12oz bottle every 4500 miles or more also with excellent results.
Bought my 2010 CPO Blutec two years ago and 4 months into ownership, discovered a water problem. After two filter changes in a year, I've been using SeaFoam to try to prevent the water problem for about a year now. Recently had a HPFP fail and Dealer blamed me for using SeaFoam as causing the HPFP to fail. Looking at VWTDI and other CR forums, the HPFP failure was probably imminent, and may or may not have been related to the additive, per Bertrand Russell's teapot.
Hi! I'm experimenting with 2-stroke oil mixed 1:200 in the diesel. So far results have been very good, and idle on my OM612 now have a bit of the characteristic pre-chamber sound! Noise from the injectors are reduced significantly!
I even read on a German forum that smoke level was almost reduced by 50% when using 2-stroke oil. Economy and poweroutput was increased by 3-5%.
In this part for the world it is almost common knowledge, that the Detroit 6.2L and 6.5L used in older GM trucks needs added 2-stroke oil to prevent premature IP failure. Some people also claims that engines running added 2-stroke oil are very clean inside.
I have used other additives from STP before, but not with any noticeable effect. My opinion is strictly subjective, but I'm am going to stay with 2-stroke oil as a simple and cheap way of improving the fuel.
Just thought I would point this out for people who wish to use additives, but not spend as much adding it yourself.
I found a local distributor here in TN (Seay Oil) that services a few stations around here. Seay oil has the capability of loading the stations with their "extreme diesel" that already has Power service +Cetane Boost, Slick Diesel Lubricator, HPCR detergents, and is winterized. I called up one of the stations they service and asked if they would request Seay to use the extreme diesel next time they fill and they said they would.
SO instead of buying a tank of fuel and then dropping the cash on the above additives separately, you get it already included in the fuel and for only a few cents more per gallon.
Here's the link I used, and there is a "locate distributors" tab that will let you see who in your area has this available. Just call and ask them to use it.
https://powerservicextremediesel.com/
ExploreMember
Taken from a sprinter site...
Many like to refer to BEVO and some like to state that Mother Mercedes doesn't recommend additives. That is just not true.
Mother Mercedes acknowledges that additives are required for proper engine operation. What MB and BEVO state is that the additives contained in good quality fuel from reputable suppliers is all that is needed. Assuming proper fuel quality (reports are that fuel quality in the EURO markets is better than USA fuel) they don't believe that there is any necessary advantage in secondary additives.
BEVO also acknowledges that viscosity improvers (antigel) are sometimes necessary. The trick will be finding one on the shelves in North America that MB approves. (If that approval should be important to you for some reason.) In my opinion, addition of Power Service Diesel Kleen with antigel (white jug) noticeably improves my starting during the low winter temperatures which I need to deal with. As I've stated before, I use PS regularly in winter, more sproadically in the summer. For example, if the PS jug runs dry in March it likely doesn't get replaced until late Fall.
Here's some select text from the BEVO site. The red is my highlights. The links are provided should you care to get into it more deeply.
BEVO list
http://bevo.mercedes-benz.com/bevoli...ets-sort1.html
http://bevo.mercedes-benz.com/downlo...Spec_119_0.pdf
Commonly commercially available fuels are blends of a variety of
compounds, principally hydrocarbons with different chemical and
physical properties. To meet the demands made today with
regard to fuels, the basic fuel is provided with additives during
production. These additives are chemical compounds which are
soluble in fuel and must be of an organic type (exception: lead
organic compounds in leaded fuel) and able to alter existing
properties or to add additional properties to the fuel.
These additives prevent or reduce e.g. coking of valves, deposits
of combustion products in the engine and corrosion damage in
the fuel system of gasoline engines. The practical properties of
diesel fuel can likewise be improved with additives.
Extensive research has shown that the use of gasoline and diesel
fuels with high additivity levels for the longevity and cleanliness
of engines and fuel systems, maintenance of favorable exhaust
emission values as well as achieving good operational
characteristics is a necessary measure which in the long term is
also an economic one.
In terms of the supply of such fuels, the individual customer must
rely on the filling stations that he/she visits selling such fuels with
additives; the opinion of large companies passed>on to us has
shown that this is the case nationally, and is usually the case in
respect of independent filling stations not tied to major suppliers.
Fleet customers are usually able to ensure the supply of products
with additives in bilateral negotiations; we recommend these
customers to insist forcefully on such fuels.
The correct selection, application and metering of such additives
depend on detailed research in the laboratory, on test benches
and in vehicles, so that the effect of the additives is optimized for
the respective fuel, additives are adapted to each other and do
not cause any negative side effects. Since the consumer will
generally not have the required facilities for this, mixing additives
to fuels may be the exclusive preserve of the manufacturers of
such fuels.
However, drivers are constantly being offered fuel additives with
the promise of huge success, such as higher engine output at
lower fuel consumption, for example. For better distinction, we
have given these additives the name of secondary additives.
Our vehicle engines do not require such secondary additives, since
in most cases uniform and adequate grades of fuel can be
assumed. If in some countries diesel fuels have less favorable
characteristics (e.g. high content of sulfur), the use of engine oils
approved by us is particularly important. Additionally, any
increase of the sulfur content in diesel fuel goes hand>in>hand
with a reduction in engine oil>change intervals (generally
regulated using the onboard computer [ edit: aka ASSYST for Sprinters] ),
this measure is significantly more effective than adding any secondary additives.
Special attention should be paid to making sure that only the fuel
grade recommended by us is used. The use of secondary additives
on the other hand, only involves additional and unnecessary
expense.
The application of secondary additives is always at the sole risk of
the operator of the vehicle, since their use may impair the
warranty issued both by the manufacturer of the vehicle and the
fuel supplier; for gasoline vehicles with catalytic converters and
diesel vehicles with particulate filters, it should be categorically
avoided.
An exception to this are certain flow improvers or microbiocides.
It is possible, to a certain extent, for these to improve the low>
temperature properties of diesel fuel or to avoid the growth of
microorganisms in diesel fuel. Only the products approved on the
relevant Sheet 137.1 and 138.1, respectively, may be used. It is
important to refer to the corresponding notes. Use of such
additives should be regarded as an exceptional measure in the last
resort.
http://bevo.mercedes-benz.com/downlo...Spec_131_0.pdf
Additives
With regard to the service life and cleanliness of the engines and
fuel systems, the retention of favorable exhaust>emission values
as well as the attainment of an overall positive operating
behavior, the use of diesel fuel with high additivity levels
represents a necessary measure which in the long term is also
inexpensive.
Large customers are generally in a position to enter into bilateral
negotiations that guarantee the supply of products containing
additives; we would recommend these customers to demand that
they are provided with such fuels only.
We would expressly like to point out that according to our
assessment the slight percentage increase in fuel costs is more
than compensated for by the savings in terms of maintenance and
servicing and the lower susceptibility for repair work. Typical
complaints that can be prevented from occurring through the use
of increased additives in the fuels are, e.g. coking of injection
nozzles, wear and corrosive damages throughout the entire fuel
system. Apart from this constantly improving exhaust>emission
values help to take the burden off the environment.
The fuel additive gains greater significance when the problems
associated with lubricity in sulfur>free fuels is entered into the
equation (see section on "Lubricity")Looked at in this way
optimizing the additive process is no longer an option, but a
necessity.
The additive process should be undertaken by the supplier as part
of its quality assurance responsibility with regard to the fuels, the
addition of secondary additives by the customer is not
recommended.
Lubricity
The reduction in sulfur content for environmental reasons which
has taken place during the past few years has brought with it the
problem of the diesel fuel's lubricity, because hydrogenation of
the middle distillate which was required to gain the reduction,
also caused the removal of the natural lubrication enhancers.
There is evidence that diesel fuels that comply with the European
limit of max. 350 mg/kg as of 1.1.2005
max. 50 or 10 mg/kg (sulfur>free diesel fuel is to be available "in a
geographically balanced manner") may cause sulfur wear in the
injector equipment. This means that the addition of lubricant
enhancing additives by the fuel producers is absolutely essential if
our customers are to be protected against long>term damage.
[I use USA fuel which is reportedly a lower standard fuel.]
EN 590 regulates this through specifications in the "HFRR test"
("High Frequency Reciprocating Rig Test"), in which a ball is put
into forced oscillation under load on a plate, whereby the diesel
fuel to be tested serves as lubricating medium. This test is in
existence both as a CEC specification (CEC F>06>A96) and an ISO
testing technique (ISO 12156>1). The maximum permissible limit
value for the lubricity in the HFRR test has been defined in EN 590
at 460 μm at 60 ∞C.
Although the method is largely accepted in the industry, point of
criticisms regarding precision and meaningfulness (i.e. correlation
with practice) of the test still exist.
Low>temperature behavior
The hydrocarbon compounds generally looked on favorably for
operation in diesel engines have a big disadvantage; they are not
resistant to cold, i.e. even at a few degrees below zero, they form
paraffins in the form of crystals. These paraffin crystals, that
"coalesce", plug up the fuel filter, fuel lines and injection system
and as a result they render operation impossible. Indeed although
it is frequently possible to start the engine, it soon comes to a
standstill. This does not damage the engine, and once the fuel has
warmed up the fuel regains its flowability. From a measuring
technique point of view attempts have been undertaken to solve
the problem with the so>called cloud point, the pour point and
the cold filter plugging point (CFPP).
Depending upon the method of fuel production and the vehicle
configuration it was possible in practice to transfer these
parameters more or less successfully. Today the "filterability limit
value" is generally given in terms of the "Cold Filter Plugging
Point" (EN 116). In this method, abbreviated to CFPP, the lowest
temperature is calculated at which a given fuel quantity flows
through a specified filter within a definite period of time.
According to the standard this limit value lies below 0 ∞C in
summer, and it lies below >20 ∞C in winter. During the transitional
period a max. of >10 ∞C is permitted. Even when normally a
provision of at least 3 ∞C is also given, it is obvious that when the
temperatures drop, difficulties cannot be ruled out. One can
improve the low>temperature resistance of diesel by adding
petroleum (kerosene) in good time.
Apart from a certain drop in performance this has no negative
effect on the engine, as long as the given maximum values are not
exceeded. With regard to such blends however, organizational
problems remain to be resolved, apart from that there are
customs law and safety technicality regulations that must be
adhered to. The admixture not only has a positive influence on
the low>temperature behavior, but also exerts a negative
influence on viscosity, the flash point, density and the cetane
number. There have been flowability improvers on the market for
some time now in the form of special additives. If one reads the
manufacturer's specifications, then it is apparent that such
additives can indeed be of use. Unfortunately, they do not have
the same desired affect on every kind of fuel (see to Sheet 137.0).
Now that there are several suppliers who offer diesel fuel with a
guaranteed low>temperature resistance, it is advisable to use such
fuels only. See Sheets 137.0 and 137.1
Edit: MB BEVO acknowledges that microorganisms can be a problem. Interestingly they only list one product in MB 138.1 which is GrotaMar 71. I know for a fact that there are many microbiocides (algaecides or algicides?) which are used in boat diesel fuel tanks that many people use successfully and recommend. I suspect that the same applies to antigels.
I feel the Gospel according to BEVO contradicts itself in these two separate sections. It's of no real consequence, I just enjoy pointing such things out.
http://bevo.mercedes-benz.com/downlo...Spec_137_0.pdf
1 Remedies when fuel is not sufficiently
resistant to low temperature
1.1 Admixture of kerosene, aviation
turbine fuel, gasoline in diesel fuel
i
On all Mercedes-Benz commercial
vehicles, passenger cars and vans,
the addition of kerosene or aviation
turbine fuel to improve the cold
resistance is no longer allowed
due to possible negative effects on
the injection system due to
insufficient lubricity.
The use of gasoline is prohibited due
to fuel lubricity deterioration and
safety reasons (reduced flash point).
BEVO list
such fuels.
expense.
avoided.
resort.
Additives
inexpensive.
necessity.
recommended.
Lubricity
at 460 μm at 60 ∞C.
i
i just started using archoil 6200 fuel additive, my cummins likes it in the way of smoothness but the merc om 642 always runs perfect so no improvement on perfect right?
I use Optilube. It has one of the best ratings for friction mitigation as determined by third party testing.
It is well known that the ULSD does not have the same lubricating properties as LSD and older diesel standards. Also I use their Boost product, which is almost pure hexadecane, which raises the cetane number to ensure a more complete burn during the power stroke. By the way, there is no upper safety limit to the cetane number, there is only a point in which further increasing it adds no further benefit.
As most fuel retailers fill up their tanker trucks at the same depots, we must rely on additives being blended in at a later stage in the distribution process. How much quality control is there? I don't know. I guess we have to trust that their numbers are accurate even though they don't readily publish them. If I fill up at a non-name brand station, do they put in any additives at all? I don't know.
So for me, I'm not willing to take the gamble, so I always use additives.
Regarding the oil discussions in this thread, has anyone else had issues or catastrophic failure using MB Mobil 1 5W-40 ESP throughout the life of their BLUETEC? Current MB data and specs now show that this is not an approved oil for the OM642. The OM642 engine in my 2010 ML350 BLUETEC only lasted 82K miles, and I've kept details of my MBUSA experience in my thread as found here:
https://mbworld.org/forums/diesel-fo...-seized-4.html
Any insight or guidance on this topic towards building a legal case against MBUSA is appreciated.
I don't have anything to add but you can check Wikipedia's references:
https://en.wikipedia.org/wiki/Mercedes-Benz_OM642
Just picked up some PS for the winter, i can't see anything but upside and it's such an inexpensive add there's no reason not too. Should make the wife vw polute a little less too.... I hope..f
I buy the Optilube and Optilube Boost in gallon jugs. I do a dose of each in each tank, which only costs me about $4 per tank. That raises my cetane number about 12 points, which ensures that whatever station I fill up at I will end up with at least a cetane number of 52 and as high as 66. That with my EGR delete will maximize my power and prevent production of soot.
Something Canadians should consider regarding the decision to use additives. Canada only requires voluntary reporting and compliance.
From the Pembina Institute:
Quote:
When reviewing these jurisdictions, it was noted that Canada has the fewest mandatory requirements for fuel quality and the least stringent monitoring and enforcement practices
http://www.pembina.org/reports/fuel-quality-canada.pdfWhen reviewing these jurisdictions, it was noted that Canada has the fewest mandatory requirements for fuel quality and the least stringent monitoring and enforcement practices
Just for everyone's information, I was looking up the content of Alkyl nitrates (the cetane boosting additive) in both PS and Opti-lube. Concentration by weight according to MSDS:
PS Diesel additive + Cetane Boost 10 - 20% - Alkyl nitrates
Opti-lube Boost! 70% - 2-Ethylhexyl nitrate
Opti-lube XPD 6.6 - 13% - 2-Ethylhexyl nitrate
Amsoil Diesel Cetane Boost - 60 - 100% 2-Ethylhexyl nitrate
Yup, Originally Posted by marc hanna
Something Canadians should consider regarding the decision to use additives. Canada only requires voluntary reporting and compliance.From the Pembina Institute:
why am i not surprised...Whatever the reason may be, it's apparent that we cannot trust that diesel fuel in Canada meets the minimum standards or those required for reliable operation of the engine.
