W211 US e320 Blutech DPF Delete possibilities?
Old May 16, 2012 | 06:09 PM
diesel2fast4u's Avatar
Chrysler 300C CRD srt
Originally Posted by Whargoul
Clearly you've never works with a computerized engine before.
Emptying the DPF will create an expansion chamber that will cause high exhaust backpressure. It will also cause differential pressure readings too low in the pressure sensors. Both of which will reduce engine power.
Unplugging the EGR and/or MAF will cause the engine to go into limp mode.
Old May 17, 2012 | 03:34 PM
tnadanzig's Avatar
Jeep Grand Cherokee CRD
I have been running with an empty dpf and egr delete for several thousand miles with zero problems. This is my wife's vehicle so if it was a problem I would probably be history. Its all in the ECM tuning. I even get about a 2.5 mpg gain in city driving. The best thing to do for a diesel engine is remove the dpf and egr those are the two worst things for engine longevity.
Old May 17, 2012 | 11:40 PM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
I can get that too, without stuffing up the rest of the system. All I have to do is drive so I am a PITA to all other motorists.
