Oil is Midnight Black at 3500 miles. Is this normal? MLDiesel'12
Absolute Rubbish.Exhaust particles do cause lung damage.
Please read plus countless other articles on the subject:-
http://faculty.kaust.edu.sa/sites/fa...?AbstractId=20
2012 S350 Bluetec 4Matic, Diamond White, P2
If the oil is doing its job, it will not be amber for very long after being in a diesel. The combustion cycle is very different from a gasoline engine. Soot and ash are abundant particulates that result from diesel combustion. The oil suspends these particulates, which darken it. There is ample capacity for suspension and lubricity in modern oils to last much longer than even the longest recommended service intervals. It is not unusual for large diesel truck to go 50-100k miles on an oil change with only the addition of a second filter. The color of the oil is truly nothing to be concerned about. Now...go drive the damn thing and quit worrying.
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
Agreed ImInPA.
Even if you removed the sump, steamcleaned the crankcase and galleries, there would still be enough black oil to discolour a fresh oil fill within a minute.
PS: I certainly don't recommend you try this!
#32
Points well taken. Thank you for the input.
2nd note. Almost got knocked out by the potent ammonia in the exhaust fumes! Dropped a tissue box after opening the trunk, bent over to pick it up and my nostrils were in frank disagreement!
I trully do miss the black sooty stink of pre-blutec diesels. Infact, there is a portion of concrete in my garage that is discolored from the 300D exhaust soot.
