removing fuel injectors
Old May 15, 2012 | 12:32 AM
arturo71's Avatar
e300 diesel
What is the right socket for removing the fuel injectors? I've got a 97 E300 diesel, and I'd like to remove the injectors without stripping the sides.
Old May 16, 2012 | 08:35 AM
Whargoul's Avatar
1985 300DT
Craftsman 27mm deep sockets are long enough to clear the injectors. Cheap-o ones like harbor freight will not.
Old May 16, 2012 | 11:21 AM
EdzBenz's Avatar
W210 W140
Be mindful of the fuel nipples on top of the injectors. I bought a special socket to remove my 606 injectors which had cutouts so no part of the socket touched the fuel nipples.
Old May 19, 2012 | 02:11 AM
arturo71's Avatar
e300 diesel
hmm...27mm sounds a bit big....also, the sides of the injector are smooth with the exception of the top, which has two flat sides next to the fuel return nipples....
I have standard fractional inch and metric deep sockets, but it looks like a 20mm is what I need.....
Why the cutout on the specialty socket?
I've seen one such socket on ebay, but I have no way of knowing if that will fit the fuel injectors that are in my car....
Any thoughts?
Old May 19, 2012 | 12:30 PM
arturo71's Avatar
e300 diesel
Originally Posted by Plutoe
Keep it simple and purchase the appropriate tool-----why the cut out-------- read my 051512 post. all is clear!!
I have found the sockets you mentioned on ebay...a vendor called El Paso tool.(see below)..they sell a MB socket, but I have no idea if this is going to fit my particular fuel injectors...there are different models and different years..
Old Oct 23, 2020 | 02:31 PM
tropicalman59's Avatar
97 E300 & 83 240D
Question Replacing Injectors 97 E300
I got a tool that fits over the new injectors, but it will not go over the old ones. It seems that there is a lip in the valve cover that will not let the tool go all the way in. I just want to verify, do I have to remover the valve cover in order to replace the injectors?
Old Oct 23, 2020 | 02:53 PM
97 E300 & 83 240D
It is a 1997 E300. I attached pictures of the tool. Also, in the last picture, you can see the lip that does not let the tool all the way in. Is that normal, or do I need a different tool?
Old Oct 31, 2021 | 11:26 PM
PaulMon's Avatar
E300
I have the same issue
I have the same issues. Did you remove the valve cover? My tool is having trouble clearing the nipples on the top of the injectors, too. Is it OK to bend them a little?
