05 E320 CDI idle surge issue
Old Jul 29, 2012 | 10:06 AM
MPH 350SDL's Avatar
1991 350SDL, 2006 E320CDI, 1999 F250 7.3L Crew Cab 4X4
My boss has a 05 E320 CDI that has developed a "surge" or "seat of the pants vibration" at idle. This is more pronounced when you have the A/C system on. The wierd thing is it seems to be intermittant. The car does appear to idle correctly when the climate control system is off. We have tried puttig the car in neutral, then in drive with no changes. You can't feel it once you are moving and are at cruise speed, only when stopped. The A/C system is operating efficently, it's been 100 degrees in NC and it cools the cabin fine.
Any ideas before a trip to the dealership?
Old Jul 29, 2012 | 12:47 PM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
Could be imbalance in the A/C pump. Bent shaft or similar. It would be intermittant as the AC cycles on/off as you drive.
Old Jul 29, 2012 | 04:29 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Can you briefly run the engine with the serpentine belt removed to see whether the vibration stops at idle ?
Old Jul 30, 2012 | 07:59 AM
MPH 350SDL's Avatar
Carsy,
I appreciate your thought process, but if we need to go through all of that, it will go to the dealer. This would take the a/c out of the picture.
