C220 diesel problem
What is the possibility of disconnecting the sensor & running the car.?
Is ther any down side to this as you are considering a new fuel pump.?
Also can you give a little info about these faults:
-Fault in CAN communication with traction system
-Clutch switch or starter lockout and reversing lamp switch
-receiving ECU
- brake assistant
- fuel type con. faulty
The machine called Reflex showed them like that, not any codes *bummer*. Do I need to get the car to the dealer and read the fault codes with STAR to get bettter view what's wrong with my car?
