w211 e320 turbo upgrade
Old Sep 22, 2014 | 01:42 PM
diesel2fast4u's Avatar
Chrysler 300C CRD srt
Originally Posted by Polomotorsports
Im stuck deciding between a e55 or e320 bluetec/cdi. So the question here is, could i upgrade the turbo on the diesel to get more power? Money is no option here so yes i know its going to cost $$$. I love diesel so i would like to stick with it...but i need power.
And if money is no object get the supercharged fuel one...
The V6 cdi is a great engine but to get near that performance you would need to change alot. First of all the intake is very bad. As the turbo is in the V you cannot fit anything bigger then the 2260 from the 265hp one. also the High pressure pump would need to be upgraded, you would need to get compression down to around 16:1 (also pistons from the 265Hp)
To get safe 300HP you need the turbo, EGR block & DPF off. Tuning you need a guy who knows his stuff as there is a torque control for the transmission.
Then the auto trans. The E55 has the speedshift installed...
Old Sep 23, 2014 | 09:06 AM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
Originally Posted by diesel2fast4u
The make things clear :
OM613 & OM648 are inline 6 cil 3.2 liter cdi
OM642 = V6
On the inline, you need injectors as they will only be good to around 55HP/cilinder. The 400CDI pump is almost bolt on (you have to cut a little in the aluminium of the timing cover) or use the 30cdi part. Also you need the injector rail line from 30CDI (see pics)
The V6 is completely different
And 628 is V8. If I remember correctly you wanted to modify this engine for marine use, right? How this project go?
Even direct bolt on (with some modification), I am not sure about the space in the engine bay, for installing pump from V8.
OEM 648 pump can be modified to flow 45% more fuel, so this is my way to go, plus if you look the engine, it looks bone stock, same with the turbo.
Old Sep 24, 2014 | 10:08 AM
Yes and OM629 is also V8
If you prefere a modified pump, no problem. The 628 & 629 is CP3 from bosch like used on cummins and duramax.
Who can modify these pumps? all the high HP 4cil, 5cil and inline 6 cilinder here use this V8 pump so it would be interesting to modify.
Biggest problem is the injectors, I had C30CDI nozzles fitted into the standard injector but the result was only 6% more fuel, so AMG does also internal work to them.
Old Sep 26, 2014 | 07:13 PM
isstay's Avatar
After pump upgrade on the OEM pump (OM648) flow rate is increased by 45%. Most diesel tuning places will be able to do it if they do upgrades on CP3 pumps for Duramax or Cummins, same with the nozzles. V6 pump will require shaft upgrade, I think, because it is gear driven.
Old Nov 9, 2014 | 02:23 AM
tuikku's Avatar
C200cdi
MB W211 320cdi, V6
Mods:
Bigger cooler and downpipe, hybrid 2259 turbo, made in stock body.
Software
No other mods.
375 hp / 3740 rpm
845 Nm / 2771 rpm
With older in line 6cyl 320, OM648, CR pump is good up to ~350hp.
After that, older V8, or 3,0 AMG pump.
Hi, for a long time.
Old Feb 11, 2020 | 10:41 AM
Vasilache Vlad's Avatar
Mercedes ML
You can use the 2260VKLR from the 265 HP 0M642.
Its almost plug and play, you need to change the turbo mount and supply water to the turbo as it is water cooled.
DPF & EGR delete + good tuning will get you around 310 HP and 700nm +
The piezo injectors are very big no need for upgrade, you will be running out of fuel before running out of injector capacity, they are able to make north of 80HP/cilincer
I did the upgrade on mine 60.000 km ago and still running very strong
Congrats on your work man.
I have seen somewhere another reccomandation for this mod you made, a MAP and a rail pressure sender from an E250 cdi.
Are those just for 300+hp or a must anyway?
Old Sep 3, 2020 | 06:10 AM
  #32
ersepias's Avatar
W211 E320
Smile
error
Old Sep 4, 2020 | 04:19 AM
  #33
ersepias's Avatar
W211 E320
Hello guys. I have seen this message from colleague and was interested in installing it in my car. It's possible? I have a 2003 w211 E320 6L:
Model E 320 CDI
Engine 648961 30 006490
Transmission 722 626 04 127 360
I have reprogrammed the control unit and the car has 240cv. I have not tested power bank to check exactly the power and torque. Do you think it is possible to make this modification? or is there another possibility to increase power? Thanks for the help.
Old Oct 19, 2020 | 05:56 AM
  #34
ersepias's Avatar
W211 E320
Model E 320 CDI
Hello, can you help me? Thanks
Old Mar 13, 2021 | 11:26 PM
  #35
Zsolt Lengyel's Avatar
w211 e320 bluetec
V6 are reliable all the work in the v6 center bay do it yourself and learn about the
Originally Posted by Micah / AF1 Rac
I also own a v6 Sprinter cdi, I can absolutely assure you that I've done more work on it in 40k miles than 145k miles on my inline six daily driver and expect only more BS btw. Just wait till you have to do anything involving the center of the V on the motor.
they are not bad to work on at all easy just gotta put urself there
Old Jun 19, 2025 | 03:20 AM
  #36
ersepias's Avatar
W211 E320
Hello. Has anyone done this modification for the OM648 320 6L?
