Clurch power bleed didn't work
Old Jan 28, 2016 | 11:00 PM
Austen Twichell's Avatar
300cd
So let me start from the beginning. My slave cylinder went out. I replaced it, Bled the clutch and it didn't pressurize. I stripped out my bleeder screw and got a new one. I read that you need to power bleed clutches. So I rigged up a power bleeder out of out of a weed sprayer and some plastic hosing. on my first attempt brake fluid started leeking turns out the bleeder screw was a slightly odd sise so I took it out and wrapped the threads in teflon tape powerbled through the slave cylinder. The clutch is really pressurized really well, but the gears grind when I push it in. Throwout bearing possably?
Old Jan 29, 2016 | 03:50 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
You possibly have not yet bled all the air out.
Did you do a lot of clutch actions ie up down, up down before bleeding again ?.
Plenty of clutch fluid in the reservoir ?.
Have you checked the clutch adjustment?. Just a little free play.
Old Jul 21, 2018 | 04:00 PM
hkycoldrct's Avatar
2002 C32 ///AMG
delete
Old Jul 21, 2018 | 04:03 PM
hkycoldrct's Avatar
2002 C32 ///AMG
anyone have a drawing, diagram or photo of where the N3/10 ME Control unit is located under the hood?
