No Turbo Boost E320 BlueTec
2008 MB E320 BlueTec. 2011 Porsche Boxster 987. 2016 Mazda CX-5 Sport MT, 1995 BMW K75 motorcycle
I have posted earlier that my Check Engine light was on and the car was sluggish and underpowered. Plutoe, on this site, suggested it was sensor B60 and with that info I went to the dealer who kept the car for 9 days (!), incl. Christmas. A seal on the turbo was replaced but the Check Engine light is still on and the car is as sluggish as it was before. Apparently they don't know how to fix it even when, according to them, their "Chief Mechanic" worked on it.
When I floor the accelerator pedal there is no transmission kick-down or turbo boost. A Fiat 500 can fly by me.
A diagnostic Fault Reading was done at my friendly parts store with the following read outs:
Definition: "Code P0111 indicates that the Intake Air Temp Sensor 1 electrical circuit was out of range or had a performance problem for a predetermined period of time". The Error Codes Read:
P0299 Turbo /Super Charger Underboost
P0473 Exhaust Pressure Sensor High Input
P0471 Exhaust Pressure Sensor Range/Performance
P0100 Mass or Volume Air Flow Circuit
I'm sure the MB dealer could get these readings and more but I have no clue why they can't seem to fix it. I needed the car back after all this time and they told me just to bring it back later. I'm not sure if I will.
Is there anyone out there who can shed some light on this? I'd sure greatly appreciate it!
2008 E320 BlueTec 90,500 miles WDBUF22X78B316368
It's not that I don't believe your story, but no MB tech worth his salt would ever start to work on a car without first getting the results for the DAS Xentry quick test that all owners can request a copy so they know what and how the car was diagnosed------post a copy or list the faults that the new car dealer found to be faulty!!
Schnellfahrer (01-01-2017)
Plutoe, I will request the "DAS Xentry quick test" from the dealer. Since they have not been very forthcoming thus far I doubt they will provide it but I will certainly try. As soon as I have this I will post it.
In the meantime I'm trying to find an independent MB repair shop but the closest is some 100 miles away. A real problem if they need to keep the car overnight.
Thanks for your continued input.
2007 W204 220CDI Classic Sedan
Do these turbos have vanes that can stick? ie exhaust pressure high & turbo air low boost.
Schnellfahrer (01-02-2017)
Carsy, I don't know about potential sticking turbo vanes but I will bring that up, as well.
Thanks mate!
Thanks mate!
Dear Sirs, your kind advice is kindly appreciated.
I own a GL350 bluetec 2012 diesel with 150 thousand Km onboard. We have replaced the inter-cooler radiator due to an accident and one intercooler hose connected to the throttle valve.
The faults accuring now are the B60 Internal fault in the Back presure sensor (actual and B28/8 differentila pressure sometimes)
We have replaced the DPF even though the old one had good values, checked the Turbo which seemed to be perfectly working, the turbo module is also working fine. Cleaned the EGR which was also working fine. We are going crasy with this car..
the car idles with low back presure about 650 while specified range is (700-2000) and jumps to 3000 or to 4600 values at boost. The boost reaches up to 3000 rpm and never more.
can somebody advice pls
SLK55 AMG, E320 BlueTec, ML350, (formerly) C32 AMG, MR2 Turbo, HD-FLH-FSE, BMW R100RS, Ducati M900
No boost
1.) Clogged DPF - do you drive mostly city? or mostly highway? Lack of exhaust flow would prevent boost and kill performance. This is consistent with high exhaust back pressure.
2.) Stuck waste gate. This would bypass hot section on the turbo and prevent boost. But, should not show high exhaust pressure.
3.) Bad turbo bearing. The friction would slow or stall the turbine causing loss of boost. May or may not cause high ex pressure? They replaced a turbo seal? Where? Was it on the bearing/bushing of the turbo shaft? or on the compressor connections? etc. Why was it replaced? They had to be seeing a symptom to point them in this direction.
4.) Leaking inlet tract downstream of turbo. This will blow all of the boost out under the hood and cause loss of performance. Usually makes noise but may or may not depending on severity. Turbo will still spin up freely but fails to generate manifold pressure. Various connections or seals can allow this, especially if the turbo has been removed and possibly not correctly replaced or not tightened sufficiently and allowed to get loose enough to blow a seal. Easy to fix but some times hard to find.
5.) Other - Does your car have the watercooled intercooler? These can be faulty. I am not familiar enough to know this. Had a supercharged AMG that had this. The coolant pump would fail and even when working would sometimes lack sufficient flow to maintain adequate cooling to inlet tract. Fault would be high inlet air temp and cause limp mode. I am guessing this is NOT your issue. 1, 2 or 4 seem more likely culprits. Ask them if turbo impeller spins freely? If so, check DPF, clean or replace. If not DPF, look for leaking inlet tract seals. Waste gate is pretty reliable and do not fail often but if turbo was out of car can often be incorrectly reconnected. This will not happen when driving and car is working fine and then stops working. It is a symptom of either bad maintenance or incorrect reassembly (IMO).
One clue would be this. Did the problem appear suddenly? or gradually over time. DPF will not clog suddenly but inlet seal or turbo bearing failure can.
Irish
Sounds Familiar
Just got our E320 Bluetec back from mechanic after having the same loss of acceleration issues.
Specifically, good turbo boost and acceleration at start up, then fail! Limp mode low power sadness.
Heartbreaking lack of power, pull over turn off and restart, then BOOM, power restored for one shot!
Dealer solution: Replace Turbo, Intake and Exhaust manifolds, cost estimate $5400.
Second Mechanic tried a few things, had trouble interpreting codes, gave similar diagnosis, cost estimate $4500.
Third mechanic (Hail Mary suggestion before dumping car) saw conflicting codes and started taking intake/turbo system apart to inspect.
Found high pressure (post turbo) hose split on underside.
Split pops open, lose boost, car goes limp.
New hose:$139, labor $125.
Result?
Power restored, mileage improved, E320 back!
Lovin' It!
Result?
Lovin' It!
1922 Ford Model T / no OBD
Result?
Lovin' It!
Result?
Lovin' It!
the <<< 7 sec rated car was taking 10 seconds. Bought it from Ford dealer, so no help there, but the price was right.
At home I found cracked intercooler hose. The mechanics did not want to spend 90 seconds to disconnect the hose the right way, so kinked $139 hose instead.
So new hose + new air filters and car shaved 2 seconds from acceleration time.
2007 E320 Bluetec..........worn turbo from poor air filter replacements.........car goes into limp mode........no turbo boost. Replaced turbo and associated sensors.......boost and back pressure sensors......still same thing. Run car through a BG "engine cleaning
de-carbonizing" system........some performance restored, but turbo kicks out after a few engagements...........now I think the catalytic converter is still clogged. I have seen videos of them removing the DPF and catalytic converter and cleaning them and re-installing. The only code it is throwing is the out of range exhaust back pressure.
Has anyone had experience with doing/having this done? a replacement catalytic converter is about $950 plus a $200 core charge (remanufactured from Germany).
[QUOTE=montgoma;7565712]2007 E320 Bluetec..........worn turbo from poor air filter replacements.........car goes into limp mode........no turbo boost. Replaced turbo and associated sensors.......boost and back pressure sensors......still same thing. Run car through a BG "engine cleaning
Had the exact same issues. Over a few weeks it threw out several confusing codes.
Took it to three mechanics who all gave us different but super expensive "fixes".
Even some of the ones you have tried.
Through a fluke of nature we were sent to an old school mechanic who took it apart piece by piece and found a split in the hose between the air filter and the intake.
Also found a small crack in the plastic cowling at the filter side. None of these were large open splits, but under pressure they lost pressure and sent the turbo a terminate signal.
HE thinks the process of replacing air filters stresses these parts and if they get old and the mechanic is not careful...hey, I'm gettin' older, too.
The cost of replacement was in the low hundreds, so we stress tested the plastic at the other end of that flexible hose and found it was about to crack so we replaced that as well.
Total cost with new filter and oil change under $1000.
Worth looking at.
Worth looking at.
ok.....left out that in replacing the turbo (oil pushing thru the bearings and the vanes DESTROYED), the turbo was destroyed when I bought the car 5 years ago. I felt lucky to get 60K miles out of it after I bought the car. My mechanic also split the cowl, which further damaged the original turbo., I also replaced the "cowling" that connects the two air fillters to the intake which replaced the mass air sensors.........
If it makes boost normal a few times I doubt turbo is the cause, they either work or not. On my OM648 I had a similar issue with a tiny pressure loss/leak at fuel filter. New filter, hoses and clamps....fixed. Stock turbo at 216k miles now. I have zero emissions control stuff and non stock flash and it’s a different motor but I also own an OM642 powered Sprinter and when under warranty it had a few of these issues, it was never the turbo, always something much more mundane.
agreed....the reason I replaced the turbo, was because of the visible damage. (oil (lots of it) present on the vane side of turbo and the vane were being ate away by the debris present from the damaged air duct)
Yes, sorry I use a lot of aviation terminology when speaking of turbos as they are basically centrifugal gas turbines using our motor as the “burner box or flame cans”. Hot side = Exhaust, Cold Side = Intake or Compressor side. Compressor erorosion of the tips is usually caused by FOD (foreign object debris) like a failed inlet pipe or filter will allow, oil pooling on the compressor side is often not from the turbo but from the crankcase breather, hence the reason many turbo car folks use a catch tank instead of allowing the case vent to be routed to the low pressure zone in the turbo air feed pipe post filter. At 216k miles my turbo does leak a TINY amount of oil from shaft seals but it’s insignificant to me, not even a liter per 10-15k miles of road use.
Next trip I take in my Sprinter I’ll log some boost readings. I assume it’s new OM642 probably runs slightly lower boost than say an e320 Bluetec but I might be surprised. My Sprinter is dead stock so unlike my w211 my numbers off it may actually be of more value to more folks than off my OM648. Now that local ambient air temps are the mid 80’s in evening time I might be able to log a run without exceeding 55C IAT and see what it does actually make?
My current setup on my W211 has seen as high as 33 psi boost on the OM648 but normally 29-30 is about peak number around 2500 rpm. No EGR, non stock mapping, +1 small step on IC core, flapperless manifold...etc.
quick update......pulled the EGR valve, cleaned it. Does not appear to be the problem. Next step is to pull the Catalytic converter and Diesel Particulate Filter (cost to replace $3500 with remanned parts......$1500 of this is core charges). We have decided to try to clean the units with oven cleaner.........should that fail, then we will consider hollowing the units out......
33.1 psi (3.1 Bar) is highest I’ve ever logged on my non stock OM648! That was at 9,400 feet above sea level too, my turbine was spinning and air was cool. I normally see 22-28 psig in my Ford F-250 and f350 work trucks, one with 6 liter, the smaller with 7.3 liter. My Jeep Liberty KJ has seen a bit over 22 and it has every stupid mod, nothing seems to REALLY work without smoke at low end except my current setup. Just some ideas, been driving naturally aspirated sorting some issues with the wife’s Genesis Coupe getting it ready for resale, the last couple weeks, man, Hyundai builds an awesome car, if you haven’t tried one, seriously do, arguably the best sports car I’ve driven at length since my old 92 NSX Honda. 345 bhp or so at crank on decent fuel with VERY light mods. If I were keeping headers and few more things would be coming soon. Oh I’m on track for a genuine 27 mpg in my daily commuter cycle too?
If only Hyundai /Kia saw fit to bring their diesels here to the USA, I’ve tented them all over the world. A Kia Dtinger CRDTi with AWD and a manual transmission would be my Christmas present to myself. I always get myself the best presents, usually European firearms but occasionally Japanese cameras and now Korean/American cars are allowed apparently?
