W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Wish there was an actual method to remove the whole DPF system in US-Spec OM642s. Mine is in a constant regen now that I only do short commutes and my MPG has dropped to below 20 per tank because of it...
Get two (16oz) bottles of Diesel Deep Clean or AR6400-D and use them in back to back tanks, change the oil/fuel filter and then start using a multifunctional diesel fuel additive.
The problem is NOT the DPF system, but how the car is being driven. Try holding lower gears in the city (2-3) and take it on the highway once a week or so.
Get on it every chance you get (once warmed up). The engine/DPF needs airflow and heat to keep the carbon buildup down and work at maximum efficiency.
