P2006 and P2007 codes on 2012 GL350 Bluetec
Long backstory short: I was towing, everything was fine, all of a sudden I had no power - like a block was under the throttle pedal. After a restart, the check engine light came on and I struggled to get it to 60mph on the interstate. I assume that it was in limp mode there.
I cleared the codes and pulled the plug off the swirl motor, putting a 10k resistor between the two middle contacts in the harness. The car would run okay, however it would still light up the MIL with a P2006 and/or a P2007. Thinking that maybe it was the resistance that was off, I ordered the 4.7k Ohm resistor and put that in this morning. Same problem - it runs fine, but after a couple shutdown/startup cycles, the code reappears and the MIL comes back on. Based on the fact that it will rev high and generate 21+ psi of boost, I'm assuming that it is not going in to limp mode now.
I've read about a whole bunch of Jeep CRD and Sprinter guys just bypassing that swirl motor entirely by use of the 4.7k Ohm resistor on their OM642 motors. Is the computer doing something different here that would cause that to not work? Is there a sensor that identifies the position of the vanes in the intake manifolds? Am I stuck just having to pull that stupid motor and put a new one in there?
The good news/bad news is that with the resistor, I still have the MIL but for some reason the ECU only limps when the motor itself is reporting a failure. I tried it a few different ways:
- Failed motor plugged in: Limp plus MIL
- Motor unplugged: Limp plus MIL
- 4.7k resistor: MIL but normal drivability
My GL jumped into limp mode after replacing the fuel filter.
The P2006 is showing up.
By reading your post I suspect that i might damaged one of the flap position sensors.
Do you know if there any way to check the sensor?
Second question, which bank is #1? Passenger side manifold?
Thank you
First of all, bank one will be the passenger side of the car. Each of the intake manifold Runners has one sensor located under the fuel rail. The connector for Bank One sensor is almost directly above the fuel filter. The sensor itself is bolted to the intake manifold and then the wire runs back along the fuel rail comes up and then runs forward and into its connector which is on a bracket right above the fuel filter. Check to make sure that that connector got plugged back in and that everything is plugged in very securely.
I have found, however, that that code for the manifold Runners being stuck closed does not seem to slip the car into limp mode. If the motor isn't working properly or at least if he ECU thinks the motor isn't working properly then it goes into limp mode. It could be, however, that if it's only seeing one sensor reading incorrectly it's assuming there's something wrong with the motor and that's putting the whole thing into limp mode.
I would double check that connector including disconnecting and reconnecting it just to be sure. Then with the engine not running I would clear the code then power the whole thing down start it back up and see if the code comes back.
Double checked all connections, all seems to be ok.
Unplugged and plugged back the sensor, clear alarms as you suggested.
Originally i had some oil leak via gasket connected to a plastic intake. The oil was dripping on the swirl motor plug. I cleaned the oil with brakeclean and installed two new gaskets.
Just wandering if it possible that brakeclean mixed up with some oil created/changed resistance between middle pins of the plug?
Cleared the alarm.
The alarm came back after 1min of drive.
Not sure if it is a Limp mode.
Car drives but noisy, feels like i'm driving on lower gear.
Feels like i'm using engine brakes.
What would be a proper procedure to check swirl motor or intake manifold flaps?
Thank you.
STAR can do a directed actuation of the swirl motor so that you can watch the flaps to see if they're moving, but I don't know of a way to do that without it. It's possible that the linkage has broken for one side so the ECU sees one side working and the other not so it's going to limp. That's educated guessing on my part. You could try unplugging both sensors, clearing the codes, and then seeing what happens. The more I think about it, though, I'm guessing that it will detect that resistance is 100% on the sensors and will go back to limp. The solution is probably to replace the linkages in the intakes or to have the ECU tuned to take out the swirl motor functions. It could be the motor - I think BraKleen is conductive and I know that the oil dripping in to the motor is a cause of lots of failures. Getting to that requires pulling the turbo off and some of those bolts can't be re-used.
What about this: What if you unbolted both sensors and taped them to a piece of metal? That should make the sensors think that flaps are always closed which would cause a MIL but should prevent limp mode.
Almost bought one a year ago when I was dealing with my first sprinter.
(Needed an adaptation of a map sensor).
Thank you for the direction. Will post an update to share my experience.
After reading through Jeep, sprinter forums and UK Chrysler 300C forums. Anything Bluetec cannot be tricked with the 4.7ohm resistor.
My issue is probably oil dripping on my swirl motor frying the electronics out. I did not fully seat and tighten the turbo inlet hose so oil spray was getting out destroying my swirl motor.
If you find your intake manifold linkages worn, there is no need to buy new intake manifolds. This new fix should work. The ebay link to purchase the links are in the video summary for $100 or so..
https://youtu.be/tXfy9fhc_nI
Intake Manifold Runner Connecting Rod - Mercedes Diesel 3.0L V6 https://www.ebay.com/i/282671876323
I believe this is only for the first gen bluetecs. Apparently later gen bluetec intake runners are a bit different and the seller is working on that as well..
I just had my 642 engine apart and no problem with rods, but lot of carbon buildup around the flaps at 180k miles.
So did you have your rods broken?
I just wonder if during the rods replacement you just simply broke off some of the carbon, what freed the flaps?
Other member reported need for new intake at 120k. Mine flaps work fine at 180k, although the picture show that it might not last.
So is it different fuel, sand flying under the hood that wear out rod bearing or poor assembly (doesn't happen often on MB)?
Other member made a video that main problem is crankcase ventilation valve and red seals in front of the turbo.
That all on top of famous oil cooler.
Good engines otherwise
Last edited by S-Vibes; Dec 30, 2019 at 01:52 AM. Reason: Need to correct my misunderstanding
