2013 ML 350 DPF Regen & P2201?
Old Sep 29, 2017 | 08:55 PM
turbosl2's Avatar
2013 ML350 Bluetec
I have a 2013 ML 350 with the diesel. I just turned 52k and the CEL came on with code P2201. I cleared the code because everything seems to run fine, however i want to force DPF regen because most of the trips lately have been short stops and i would like to ensure the DPF is cleaned out and make sure this is not whats causing the sensor to read .
Can you force a regen by going into the service menu? The service menu i am referring to is when you hold down the call button and a few others to enter service mode, such as when you put rear brakes on the car and need to spin the calipers back, is there a DPF regen cycle somewhere hidden i can trigger?
Old Sep 30, 2017 | 10:13 AM
turbosl2's Avatar
2013 ML350 Bluetec
anyone know about the regen process?
Old Oct 1, 2017 | 07:26 AM
mtrevelino's Avatar
2006 E320 CDI
See if you can find your answer here:
https://www.google.com/search?q=forc...utf-8&oe=utf-8
Basically, you need to run it on the highway for at least 30 miles at under 70 mph.
Mike T.
Old Oct 7, 2017 | 03:32 PM
turbosl2's Avatar
2013 ML350 Bluetec
Mike T.
nothing of use
