2012 GL350 Front Air Suspension Replacement
Old Feb 1, 2018 | 11:00 PM
overtoi's Avatar
2012 GL 350
Talking 2012 GL350 Front Air Suspension Replacement
OK. It's my turn to replace my front suspension, I'm going with Arnott because of the lifetime warranty. Does anyone have the discount code, as MBSAVE12 didn't work.
Ivan
Old Feb 2, 2018 | 01:58 PM
arnottdoug's Avatar
Former Vendor of MBWorld
MERCEDES-BENZ CL-CLASS
Arnott Discount Code for MBWorld Members
Forum members can use code MBSAVE10 to save up to 10%* off the retail prices on Arnott® replacement air suspension products for your Mercedes-Benz®. You can place your order online at the Arnott Web Store or by calling Arnott Customer Support at 1-800-251-8993 X 804 Mon – Friday from 8:00 AM to 7:00 PM ET. Orders placed by 2:30 ET are typically shipped out the same day.
*Max savings $75 per order, not valid with any other offer or on compressors, shipping, taxes or core deposits (if any).
Old Feb 4, 2018 | 11:49 PM
overtoi's Avatar
2012 GL 350
Old Feb 4, 2018 | 11:53 PM
overtoi's Avatar
2012 GL 350
Does anyone have a copy of the torque specs for the bolts that your remove when replacing the front air suspension?
Old Feb 7, 2018 | 10:25 AM
overtoi's Avatar
2012 GL 350
Ok. The shocks have been ordered and should be here by the end of the week. (if we don't have another ice storm)
Old Feb 7, 2018 | 10:56 AM
arnottdoug's Avatar
BA32.22-P-1001-03B Torque Specs for X164 with 489 Code (Airmatic)
Torque Specs for X164 Air Suspension*:
Air Line to Compressor: 3.5 Nm
4mm Air Line to Valve Unit: 2Nm
6mm Air Line to Valve Unit: 3.5Nm
Air Line to Front Struts: 5Nm
Compressor brackets to cross-member and front end: 20Nm
(*Check service manual to be sure)
Old Feb 7, 2018 | 11:19 AM
overtoi's Avatar
2012 GL 350
arnottdoug- thanks, but I'm being told by my MB dealer in Silver Springs MD that MB doesn't sale service or shop manual to the public. Not sure I trust what I see on EBAY any thoughts?
Old Feb 9, 2018 | 06:39 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I've always had good luck with AllDataDIY.com for my cars and trucks. Up to date TSB's, virtually identical service procedures as the manufacturer's manuals. Torque specs too.
No intereste in the company other than a many times over satisfied subscriber.
Old Feb 10, 2018 | 08:40 AM
overtoi's Avatar
2012 GL 350
Post Wrong repair Red arrow shows need spec
adding Pic with arrow to what I need. Upper control arm is in 2nd PIC
Thanks for the reply but I need the specs for 3 10mm bolts on the top of shock, 23mm bolt that connect the lower A-arm and the 21mm bolts for upper control arm and lower sway arm. Any help would be much appreciated.
Old Feb 10, 2018 | 08:44 AM
overtoi's Avatar
2012 GL 350
Quick update I was able to replace the drives side last night after work, took about 3 hrs because of a tool run to get some MM sockets I didn't have.
Old Feb 22, 2018 | 09:43 AM
overtoi's Avatar
2012 GL 350
Angry
Update. Today I paid for access to STAR TekInfo web site to get the torque spec for the bolts in the above post. But I was unable to find the info I need. I have access until 8am 2/23/18, if anyone could help that would be great.
IO
Old Jun 11, 2018 | 09:34 AM
overtoi's Avatar
2012 GL 350
So I'm back!! Back in 2/18 I replaced both front Air shocks with Aronott new replacement. Well on 6/9/18 after a round trip to Fredrick MD, I pull in the driveway turn off truck and I hear air sound from passenger side of car and the shock completely deflates. So I turn car back on, passenger side inflates to drive height, but I still hear air sound. Turn off truck and the passenger side completely deflates. So I have an email into Aronott to get the replacement process. I will update when I hear back. Hoping Doug Doug@arnottinc.com will make quick work of this.
Old Jun 11, 2018 | 01:05 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Don't forget to take pictures?
I am always very skeptic to "lifetime warranty".
Who's life we are talking about?
Most of the time they apply to original buyer only.
Old Jun 11, 2018 | 09:59 PM
overtoi's Avatar
2012 GL 350
OK. called Aronott today and found that I have to buy the replacement FIRST (468.00). So it's on order and should be here in few day. Should only take about 1.5-2hrs to replace this time. Then I ship the old one back and I get a FULL refund in a few days after they receive the old one. So more updates to follow. The attached video is what I hear after I start the truck let it run for 30/40 sec then turn it off.
File Type: mov
Old Jun 12, 2018 | 09:54 AM
arnottdoug's Avatar
Yes, Arnott's Limited Lifetime Warranty applies to the original purchaser and is not transferable.
Old Jun 25, 2018 | 10:45 PM
tmurphy25's Avatar
gl550
i just had all 4 air suspensions repair and front brakes.. $4950.
Dealer warrantees work for 2yrs.
Stated he sees the aftermarket products failing due to incorrect install and not the same quality as MB units.
Do I now keep this SUV for the next 10yrs?
GL550 2011 83k miles
Also last year the vehicle sensors went, that was $1500...
Any other big issues?
Old Jun 25, 2018 | 11:02 PM
overtoi's Avatar
2012 GL 350
Well, if 4950 is no be big deal to you, then keep it, I have better things to do with my money.
Old Jun 25, 2018 | 11:11 PM
overtoi's Avatar
2012 GL 350
Ok, now for the update, I installed the replacement and sent the old one back to Arnott. So far so good.
Old Jun 25, 2018 | 11:12 PM
overtoi's Avatar
2012 GL 350
Not sure how you install these wrong to the point that then fail, the instruction are very clear.
Old Jun 26, 2018 | 12:08 AM
tmurphy25's Avatar
gl550
actually it is a 9 months of car allowance... car is already paid for. I like keeping a quality car until I need to replace it.
I'm a huge fan of this SUV, and so I looked at it as an investment (put 5k in, get 3 yrs no headaches).
I know I paid a premium, but wanted to ping the group to hear about their real experience with the GL 550.
Thanks,
t
Old Jun 27, 2018 | 04:29 PM
Suprdave's Avatar
2011 R350 Bluetec
Ouch, I replaced my Rears and Compressor with Arnott for a fraction of that. They used GoodYear Bags...the OEM ones are garbage, they are warrantied for 2 years, but are guaranteed to break in 3.
Old Jun 27, 2018 | 05:42 PM
tmurphy25's Avatar
gl550
yes ouch is right. When you say a fraction, do you have a breakdown (rough) material v labor. I know I pay for the premium service at the dealer, though I just need to estimate how much.
thanks,
t
Old Jun 27, 2018 | 09:22 PM
overtoi's Avatar
2012 GL 350
Update, today I took the car out and its not doing anything. Its at what I think is off-road height and stuck there (off-road is when you push the button on the console and the body rises a few inches). I took it on the highway at 40+ mph for 1/2 mile and it didn't lower. It my understanding that at 40+plus MPH it should lower to highway height for better gas mileage and lower center of gravity. It also my understanding that is the case on all model with or without ADS. Is that true? The only thing it does is release air (pssst sound like air brakes on trunk) all the time when stop or driving. Here a link to the video of the 40+mph test. https://drive.google.com/open?id=1wW...bbbTmHT47E7-MI
Old Jun 27, 2018 | 09:23 PM
overtoi's Avatar
2012 GL 350
My guess would be 3000 parts and the rest labor.
Old Jun 27, 2018 | 09:25 PM
overtoi's Avatar
2012 GL 350
Also I can confirm now that Arnott refunded my money that they held until they got the old shock back.
