Mercedes mechanic with 52 years experience says "never buy a used Bluetec"
Old Apr 16, 2018 | 05:45 PM
Ariesfamous's Avatar
2015 cls550
Listen I'm going to explain this the best that I can and then you can carry on ranting and whining as much as you like and defending your honor.
I was looking at buying a newer Mercedes or BMW 7, so I called an independent mechanic that I've known for years that works on Mercedes and a bunch of different European vehicles. FOR LIKE 30 PLUS YEARS.
Here is how the conversation went. Try to stay with me here.
ME: " hey (insert name) , how you been? I'm looking at a 2015 7 series and a Cls550 anything I should know before I choose?
REPUTABLE INDEPENDENT MERCEDES MECHANIC : " I'd advise you to stay away from a 7 series out of warranty, and stay away from anything Blutec"
ME: " Cool, thanks buddy. Ttys when I come in to get my exhaust done."
R. I. M. M. "Np ttys"
Now write a book in response. I'm sure everyone is hanging on your extreme wisdom, lol.
Old Apr 16, 2018 | 06:11 PM
W109 W211 6.2L's Avatar
2008 W463 G500, 2003 Terminator Cobra (710RWHP), 2012 S350 Bluetec, 2010 911 C4S, 2007 VRSCDX
Cool story bro, 1 person out of Billions and no facts to back it up except that "He works on McLarens." Plenty of facts to back up the quality of the OM642 from Europe to the US and you dont own an OM642 or a Mercedes diesel. I believe the youth of today would refer to you as troll. Enjoy your Range and CL. I know this is a long read for you, sorry.
Old Apr 16, 2018 | 06:19 PM
2015 cls550
Originally Posted by W109 W211 6.2L
Cool story bro, 1 person out of Billions and no facts to back it up except that "He works on McLarens" . Plenty of facts to back up the quality of the OM642 from Europe to the US and you dont own an OM642 or a Mercedes diesel. I believe the youth of today would refer to you as troll. Enjoy your Range and CL. I know this is a long read for you, sorry.
Thanks I enjoy them both
Old Jun 14, 2018 | 12:56 AM
SndsoftheSbrbs's Avatar
2019 Audi Q8, 2015 GL63, & 2005 E500W4
I have a stretched timing chain in the midwest. I was told that the stretching is much more common in areas where the fuel has a high composition of biodiesel. In Illinois, where I live and where the car has spent most of its life, has up to 20% biodiesel. Based upon what my service consultant has told me if you have a vehicle driven in a place with pure diesel, the car should be fine.
Old Jun 14, 2018 | 10:27 PM
MBspdfrk's Avatar
2014 ML 350 Bluetec
I just bought my fourth bluetec. These have been great cars in every aspect. Not sure why the mechanic claims they are bad. I am certain if you do not do maintenance, yes, you will have problems. The older oil cooler seals are know to go bad at some point, but that is about it. Clean fuel, clean air, and clean oil. It’s that easy.
Old Jun 14, 2018 | 11:09 PM
I think it might be the diesel composition. I have no idea.
Old Jun 15, 2018 | 12:55 PM
  #32
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
I just read a comment by Isawelvis where he has a good point. Many of the MB's on the road are leases. Someone with a leased car isn't looking towards long-term reliability. He tosses the keys back to the dealer after 2-3 years and gets into a new replacement. Between that, MB with their ridiculous oil-change intervals and useless, EPA-mandated oil, not to mention some scenarios including stop'n go traffic in especially warm areas of the country.....how can a Bluetec have a fighting chance?
Old Jun 15, 2018 | 01:28 PM
  #33
Actually, warmer climates are thought to be easier on BlueTECs.
Old Jun 15, 2018 | 05:47 PM
  #34
Not according to what I've gleaned over the last year. Excessive heat is allegedly the reason for oil-cooler seal failure as well as liquid-filled engine mounts actually melting.
Important to point out that I'm referring to stop and go traffic in warm climates. Highway running doesn't seem to be blamed as an issue. As well, high engine temps cause the oil to boil off, which in turn is alleged to crud up the swirl valves and EGR. Just a mess...
Low zinc/sulphated ash/phosphorous has been blamed for engine & timing chain wear, but necessary to meet EPA standards and to save the DPF. Screw the DPF, I'd rather replace a DPF at 80 miles than a gelled engine at 100k miles.
Again, my opinion based on what I've read. For whatever that's worth...
Old Jun 15, 2018 | 09:33 PM
  #35
The oil cooler seals were failing universally due to an inadequate plastic material. I'm in northern Illinois, and mine have failed, as have those of forum members as far north as Montreal.
Old Jun 16, 2018 | 05:48 AM
  #36
An inadequate material which has been changed....and yet they still fail. You aren't reading what I posted. You could live in Alaska and have issues with the oil seals if you see a lot of stop'n go traffic. That oil cooler is buried under the top of the engine. If the under-hood temps get hot enough to melt engine mounts, don't you think that this excessive heat can cause other issues as well?
I've popped off my engine cover and belly pan for the summer (my gf, the driver, is never stuck in traffic due to her work hours), and I run 20W50 synthetic motorcycle oil, all for the same reasons mentioned by that same Mercedes mechanic who recommends staying away from Bluetecs. Mind you, I've only had the truck (with +/- 13k original miles on her) for less than a year, so I can't vouch for the long-term effects. But I will report back, regardless of if the results are positive or negative.
Old Jun 16, 2018 | 12:15 PM
  #37
MBspdfrk's Avatar
2014 ML 350 Bluetec
Which synthetic motorcycle oil do you use?
Old Jun 17, 2018 | 02:40 AM
  #38
Suprdave's Avatar
2011 R350 Bluetec
Take it for what it's worth guys...I've just gotten a Hydrogen Carbon Cleaning from a newer company CarbonTek...been running the 20w-60 Redline for the last 5-6k...
Got an Oil Sample I'm about to send in...I have more 20w-60 w Ceratec in there now...The Carbon cleaning got rid of my EGR Performance P4140 Code. It honestly runs a ton better...
The 20W-60 helped it run smoother also, but the Ceratec has really done alot to quite the engine down after like 500miles or so.
Gonna Test the Archoil Stuff next 5000miles....gonna do the Archoil Fuel Treatment next week probably tho, the Liquidmoly Fuel Treatment was ineffective imho.
Anyone in South Florida, Definitely look into getting the Carbon Cleaning done...Richard at CarbonTek was a good dude.
I'm going to update the Tensioner to the newer PN next...already have it...still have alittle slap at startup but it's MUCCCHHH better now with the better oil\ceratec and Carbon Cleaning.
People used to ask me what was wrong with my car all the time...kinda embarrassing...its noticeable how much better it is now.
Old Jun 17, 2018 | 03:39 AM
  #39
Tadas Voveris's Avatar
Mercedes-Benz s350 diesel
Help
Hi everyone i got problem
my rear parking camera not working it's showing like that yesterday i will bought new rear camera and already changed but got still same problem
anyone knowwhere the fuse of rear camera
Old Jun 17, 2018 | 06:33 AM
  #40
The choice of synthetic motorcycle oil up here in Mtl is dismal. I actually had to drive to Plattsburgh NY last winter to find any, and it was at a Walmart. But I'm aiming for Amsoil Dominator 20W50 synthetic oil....if I can find it. Designed specifically for diesels, it has a very low NOACK of 3.7%. This is the rating that measures the oil boiling point.
The best part? This oil is rated M2C171-F1, which is the oil recommended by Ford for their diesels. Ford is the one manufacturer who flipped the bird at the EPA when it advised it's diesel owners to drop the CK4-rated oil because it was garbage and causing accelerated wear etc in their engines.
Interesting point, FWIW. I run Liqui Moly engine flush thru the engine 10 minutes before an oil change. This stuff is so potent, the oil varnish in the aluminum casting in the valve cover under the oil cap turns to bright aluminum the second this stuff hits it. Problem is, there's so much stuff cleaned off the inside of the engine that the subsequent fresh oil is black within 10 seconds. So my new protocol is;
- Run engine flush 10 minutes prior to oil change
- Drain oil
- Fill with the cheapest $8/gallon diesel oil available
- Run the engine for a minute or two
- Drain oil and replace oil filter
- Fill crankcase with Amsoil 20W50
Haven't done this yet, but the truck is up for an oil change in about 1k miles. Will report back then
Old Jun 17, 2018 | 01:38 PM
  #41
kajtek1's Avatar
1922 Ford Model T / no OBD
The light-brown "varnish" on engine internal surfaces is perfectly normal stuff.
It is like blue/black marks on torch tip. You don't dump torch into acid after each use to bring the shiny metal?
Old Jun 17, 2018 | 02:14 PM
  #42
Of course not. I was merely making a point about how potent the cleaner is. I've never ever poured an engine flush into a valve cover and seen the metal go white within milliseconds.
As well, this was the first time that an oil change resulted in the new oil being just as black as the old oil.
Old Jun 17, 2018 | 02:50 PM
  #43
Suprdave's Avatar
2011 R350 Bluetec
I have used the LiquiMoly Flush on the last 2 changes...i got like every drop of oil outta the pan with suction and drain...still turned the oil black immediately.
I think the only way to get rid of it completely...would be to do a flush, run with cheap oil for a few minute with another bottle of flush...then add a Bypass Oil Filter system.
Add the Good Oil and Go...The Bypass should keep the soot levels in check. IMHO the added complexity of a Bypass plus the added cost isn't worth it if you follow a 5k Oil Change.
The Good Oil (I'm using Redline 20w-60) will hold the soot in suspension better.
I'll probably be trying to a Redline Euro 5w-40 with Archoil 6100 next change and do an oil comparison between straight 20w-60, 20w-60 with Ceratec, and 5w-40 with Archoil.
Redline is the only Oil i'm going to run in this from now on...
I'll be switching all the Diff\Trans Fluids with Redline ATF, also.
I'll make a big thread with all my findings, but in meantime I'll update here.
Old Jun 17, 2018 | 03:46 PM
  #44
No way I'm using flush again on the cheapo oil. I just want to rinse the inside of the block off properly before putting in my $18/quart liquid gold.
Post your results back, I'll post mine. Due for the next oil change in ....1300 kms or 800 miles
Old Jun 17, 2018 | 09:31 PM
  #45
DanD.'s Avatar
2018 GLC 4MATIC
Sorry but what results you two are talking about?
In my understanding you need to run different oils and after each run do oils analysis in a lab.
Are you going to send your oil for analysis?
I did mine a few times, because silicon value went high after on air, turbo seals were replaced.
Also I had trace of zinc but it back to normal with frequent oil changes. Every 3-3.5K miles.
Im using MB Mobil 1 oil.
Old Jun 18, 2018 | 01:53 PM
  #46
Suprdave's Avatar
2011 R350 Bluetec
I have been just flushing before the oil change...I'm not really sweating the soot in the oil, because I'm changing at 5k. It's kinda crazy that MB recommends once a Year service interval.
I' would only do that extra flsuh if I was switching to bypass, which I don't plan on. Maybe if I had a sprinter, I would...
Old Jun 28, 2018 | 06:34 AM
  #47
Limomaster5's Avatar
Gl 350 bluetec
Originally Posted by Suprdave
Bought my 2011 with 47k. Had 2 Dealer Services that were pretty bad experiences...Along with a warranty repairs.
Rear Airmatic, Airmatic Compressor 100% will need to be replaced with Arnott Stuff.
I personally switched to the 20W-60 Redline around 66k-ish, after my last Dealer Service...which used a 15w-50 at 56k when my Oil Cooler got changed...put 10k on that Oil, car was rattling sounded terrible.
I found Stevens site, around I started getting really into the Oil stuff. I think it REALLY matters, combined with keeping the intake manifold\pvc clean. I went Redline after a Liqui Moly Flush.
Going to change it next again week with around 3,000...going out for Oil Sample to check for metal levels.
I'm going to swap it for Fresh after another LM flush and adding LM Ceratec to the 20W60 Redline.
If you are going to buy one, you better have the ENTIRE Maintainance\Warranty Service History and have it checked by a Trusted Indy before purchase.
The problem is most of these cars start off as Leases, and get a 8-12k on the oil changes if they are lucky. The oil is diluted by diesel and soot-filled...then shot back into the Turbo by the PCV system.
Also doing a Hydrogen Intake Carbon Cleaning and a Fuel System Flush w LM Diesel Cleaner, because It's getting slow to startup. After that I will start using LM Diesel Additive every other tank.
The Redline Oil already makes the car sound a MILLION times better. I get a 'slight' rattle for a half-second at cold-start but immediately goes away, like half a second. It could be because the cold-flow of the 20W-60, I'm curious to see if the Ceratec makes that go away.
I'm prepared to do a Preventative Timing Chain around 75-80k if the oil numbers don't look good.
I will probably make a full thread on my finding after I put some miles on the Ceratec\Redline Combo.
if you hear a rattle at cold startup your timing chain may be too stretched. I just had to replace mine at 100k
Old Jun 28, 2018 | 04:23 PM
  #48
There's also a recall on that same rattle, caused by oil pressure bleeding off from the hydraulic chain tensioner
