2007 ML320CDI Straight Pipe
1. Try Resonators first (Not enough sound, try removing the mufflers)
2. Mufflers (too much drone maybe consider putting the resonator back in, but leaving the muffler off)
Also back pressure is important for the motors power unless you tune for an exhaust so you might loose some low end grunt for the sacrifice of better sound. Let us know how it goes.
Good Luck
As far as losing some low end is concerned, I guess I will see what happens! I will put up some pictures when it's done.
Naturally aspirated may be a different story.
