Oil pan leak.
Old Apr 28, 2018 | 08:43 PM
Jlindsey86's Avatar
Mercedes E350, Jeep Comanche, Triumph America
Oil pan leak.
I have a slight leak from my oil pan. It seems to be coming from whatever this is. Is this a sensor of some sort and is it common for this to leak?
Old Apr 28, 2018 | 09:54 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Is it 642 engine? Would be nice to know.
No it is not common, but things happen. I think it is temp senor. Wash it and check if the leak is on the seal, or the sensor body.
Buy the part before next oil change.
Old Apr 29, 2018 | 05:28 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
If there's a perfect place to have a leak, that would be it. New sensor and crush washer and you're good to go....
Old Apr 29, 2018 | 08:05 PM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
I had exact same problem on my om642. I only had to replace the copper washer. Careful installing the sensor back in to make sure the threads go in correctly or else you'll be needing a new sensor.
