Two questions
On my 08 E320 BlueTEC since I got it back from having the timing chain and the manifolds replaced I can smell diesel exhaust in the cabin when driving the car before it warms up then it goes away. Also the fuel mileage has dropped from 36-37 mpg on the highway to 32-33. Other than that the car runs terrific.
Ive read that the exhaust smell problem could be the fuel injector seal (s). Could this also be the problem with The mileage? If so is this an expensive fix? I just spent $2500 on the beast and I’m tapped out right now.
Open the hood and stick you head under listening for hissing. You can ask somebody else to rev the engine.
But unless that is huge leak, it would not explain mpg drop.
Run some tests.
I know first-hand how hard things are to access on this engine, but if you pull the top cover, you should be able to remove passenger side flexible foam insert and at least lift driver side to take a look.
Than pulling the filters for better inspection is always an option, although I hate reiserting driver side filter housing.
Good luck.
The mold wraps around each fuel line, each connector and each electrical cable.
Its been long time since I dealt with Black Death on cdi engine but I remember that to be pretty stiff material, who made solid clog when melted by engine exhaust under injector seal.
Not tempted to see how the flexible foam melts
i screwed up on the mileage. It’s really quite good after all
I need to get one one of these cheap 07-08 Bluetech cars popping up locally with issues...by buddy at Mercedes dealer to my north just picked up a 60k mile 07 for $1800....it’s getting full treatment of mods now, can’t wait to try it out when he is done.
One more time, I love my OM642 engine although I hate to work on it.
Seems this is the main issue with them.
Then engine is too complex for average DIY to work on, while dealers will charge you 2 grands to replace $20 worth of oil cooler seals.
Same with cleaning intake flaps.
My old engine at 180 k miles never had black death and I was able to pull the injectors with regural pliers.
