Fuel Pressure Spec for In-Tank Fuel Pump
I have a 2008 Mercedes E320 BT. Does anyone know how much pressure (psi range) the in-tank fuel pump should be pumping out if it is working properly? 60 psi? 65 psi? 75 psi? I know my pump is working and putting out 60 psi consistently (on start up and load test) but I think that might be too low and causing my P2633 DTC.
Cheers.
Would you have rail pressure as well?
The code sounds like bad connection, aka dirty plug at the pump btw.
Get good contact cleaner and wash all the pump connections with it.
