Yet another oil question....
Old Jan 17, 2019 | 01:41 PM
DeutscheBenz726's Avatar
2019 E 300 4matic 2013 SLK 250
I was looking on a parts website yesterday for oil (I’m doing the 5000 mile oil change routine) and found one of the recommended oils was pentosin 5w40 oil they said was equivalent to Mercedes Benz 229.51 oil.
Since it regularly gets into the 90’s-100 degrees in the summer in Kentucky I was wondering if this would be acceptable for my 08 E320 OM642 engine. I’ve been using MB 229.52 oil in the last year and I always use the Luquimoly engine oil flush.
What say you all?
Old Jan 17, 2019 | 02:30 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I am sticking with 229.52 classification and the only weight I can find is 0-30
Seem to work fine and I frequent 120F.
Old Jan 17, 2019 | 02:59 PM
lkchris's Avatar
'10 CL550, '12 GL550
229.52 is by definition 5W-30 because the spec is for fuel economy.
with today’s synthetics that meet MB specification, the value of the winter number and the value of the high temperature number are essentially meaningless and all will perform just fine in all situations. Engines have thermostats, and in terms of heat, outside temperature is meaningless.
Old Jan 17, 2019 | 07:22 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
229.51 was the best oil.......until they decided 229.52 was better. Both garbage in my opinion, but those with intact DPF's have no choice but to use low zinc/phosphor oil.
Old Jan 17, 2019 | 07:35 PM
smiledr996s's Avatar
2008 gl320cdi
i agree. Which is why I had engine tune w/dpf delete. I now use a liqui moly oil. Their lieghlauf high tech 5w40 which is a 229.5 oil. My oil analysis has never been better and the oil is easily available. 😀
Old Jan 18, 2019 | 07:40 AM
I run Amsoil Competition oil in summer, (super high in zinc/phosphor) 20W50. In fall I run Signature Series in 10W30, and will be doing my next oil change with Signature Series 0W30 this weekend when I get back up to the Great White North. The truck always sleeps indoors and is rarely outside for long, which is why I wasn't panicking.
