Sov Removal 98 e300td
Old Mar 20, 2019 | 11:53 AM
shvlhead78's Avatar
98 e300td .2003 f350 powerstroke,2014 Chevy Cruze 2.0 Diesel
Does anybody no the size of the torx tool needed to remove Sov.
Also has anybody had difficulty removing it worried about stripping heads on bolts.
Need to replace oring on back side.
Old Mar 20, 2019 | 02:29 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Easy access once you move washer tank aside.
I remember it to be T15, but it was long time ago, so don't take my word for it.
I took front picture of SOV once I removed the tank as at the angle you can see - you don't see bolts inside the holes.
Make sure bolts heads are clean, use quality bit and you will never have a problem.
Those bolts are heat-treated so they can take some abuse.
