Move Transmission to Neutral without Battery
Old Apr 23, 2019 | 07:01 PM
TexasGL's Avatar
GL350
Hey guys, I need to tow my car GL350 2012 and would like to know if there is a way to set the transmission on neutral without battery, I tried to do a couple of times with battery in and I could not put the transmission in neutral always jump back to park, also after you remove the key goes back to park too.
The car has seized engine and been park for a while. last time I checked it there were a lot of alarms on the cluster and the windows and seats stop working ( also radio and AC blower) so I charge the battery again but nothing happened.
I would like to leave it in neutral so I can move or tow from one place to another without the battery.
If someone could give me instruction on how to put the transmission in neutral mechanically I will appreciate. Thanks
Old Apr 23, 2019 | 08:17 PM
Micah / AF1 Rac's Avatar
W211 e320 CDI
Pretty sure you need a battery, I know on my W211 it’s required, starting car isn’t but key in the run position is? Doubt that’s very helpful, you DEFINITELY can use a different than stock battery, I had to use one from my Kia to move car once?
Old Apr 24, 2019 | 01:19 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Not familiar with GL, but E of this year has 2nd battery that suppose to be just for that.
Dashboard mounted on E.
When all home ways fail - read the manual
Old Apr 24, 2019 | 04:30 PM
TexasGL's Avatar
GL350
Thanks, will recharge the battery and try again.
Old Apr 27, 2019 | 02:23 PM
nelbur's Avatar
1997 E300D
Most automatic transmissions are not lubricated when towing, so it is generally recommended that they not be towed more than 50 miles, even in neutral. If you are going farther the driveshaft should be disconnected.
Old Apr 30, 2019 | 10:20 AM
TexasGL's Avatar
GL350
Job Done, I fully charge the battery and was able to set the car in neutral, then I remove the battery and the car remain in neutral. so Im able to move the car any time I want without battery
