07 GL320CDI spontaneous braking, or fuel cut?
Old Jun 2, 2019 | 07:13 PM
Silberfuchs's Avatar
07 gl320cdi
Hey all,
I’ve found tons of great help on this forum, so thanks! I currently have a problem I haven’t been able to find any answers for.
Our 07 GL320 CDI (130,000mi)is stumbling at steady speeds/throttle position. It seems to only happen when it warms up. It feels like someone is stabbing a fantom brake pedal or there is a violent cut in fuel. It can get more and more frequent until it’s a struggle to maintain speed. It is very intermittent too. The car recently had a CEL and limp mode for EGR valve, which I replaced, and solved that problem. I don’t know if this could be related...
My first though was maybe a bad tank of diesel, and I don’t know the service history, so I replaced the fuel filter, air filters and added some injector cleaner/cetane boost. This did not solve the problem🙁
My next thought was the ABS or ESP was acting up and applying brakes for me. I pulled the abs fuse, and that did not solve the problem. It did disable power steering, which I thought was kind of strange.
The car is not throwing any codes.
I’m out of ideas. Anybody had similar problems?
Thanks for any help!
Old Jun 3, 2019 | 12:15 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
At 130k miles, assuming that replacing EGR you cleaned its pipes, next thing that comes to mind are intake flaps.
You have OM642 engine.
For some reason that MY engine is called Bluetec on sedans and cdi on SUVs.
Beats me.
Old Jun 3, 2019 | 05:35 AM
smiledr996s's Avatar
2008 gl320cdi
Happened first with faulty dpf pressure sensor. fixed by changing sendor Then with swirl valve, eliminated with tune, but there is a resistance mod for this. Either way I think you should see a code. Sounds like car going into limp mode.
never mind reread the thread. Sounds like something else. Very curious
Old Jun 3, 2019 | 08:06 AM
07 gl320cdi
Update;
I hooked up my OBD reader and drove with datalogging on. Now the car finally threw a code, p0299 Turbocharger.
When these “stumbles” occur, there are sharp dips in fuel pressure. I also took a look at the turbo, and it doesn’t look good
There is a tiny bit of wiggle in the shaft. Could it be possible some chunk got in there from the egr job? I really had to bash that sucker to get it loose.
I am thinking I might need a turbo😢
Something got in there
Orange line is fuel pressure, steady throttle at this time.
Old Jun 3, 2019 | 10:16 AM
kajtek1's Avatar
You turbo is grind with debris. You need at least new compressor wheel and intercooler flush.
Small play on the shaft is normal. I rebuild my turbo at 180k as it had some play and new bearings had the same play.
Also look like crankase ventilation pipe wasn't inserted all the way in, what created all that oil around.
Old Jun 3, 2019 | 10:33 PM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Something simple here with a possible solution.Are your air filters clean? That was my issue...
Old Jun 4, 2019 | 12:50 PM
PSDCampervan's Avatar
2005 E320 CDI (SOLD); 2008 ML320 CDI 4MATIC
There is likely a little binding going on when that impeller spools up & expands from heat against it's housing. It has probably ingested part of seal or plastic from MAF intake but the VGT actuator that adjusts impeller's exhaust side blades is a common issue as well. Apparently ICB of actuator has inadequate soldering of 3 bridge connections & if any one of them breaks, actuator will intermittently lose contact, set a DTC, lock-out ECU to limit revs to 3k so acceleration is sluggish.
Old Jun 4, 2019 | 07:07 PM
07 gl320cdi
Thanks PSDCampervan.
In searching possible solutions, I came across the actuator issue. I checked and all my connections look great still.
I'm thinking it’s time to bite the bullet and order a new turbo😔
Old Jun 5, 2019 | 12:06 AM
Towmater's Avatar
Ml350 bluetec
Rock auto has turbos for as little as $700. Not too bad.
Old Jul 1, 2019 | 08:33 AM
07 gl320cdi
Update; I bit the bullet and got a new Garrett turbo, and paid an Indy mechanic I trust to install it. Problem solved... For about two weeks😔
same symptom is back and CEL is back on. The thing I think is strange is the new turbo sounded WEIRD from the get. It was quite a bit louder, and sounded like a cat fight, for lack of a better description.
I confirmed with the mechanic that he primed oil in the new turbo. I don’t know where to look now. How likely is it that the new turbo from Garrett was a dud?
Old Jul 2, 2019 | 05:00 PM
Highly unlikely. I would be pulling intakes off and inspecting for carbon/oil deposits. Have a feeling your head intake ports are totally gummed up and your engine is choking.
