where to buy adblue
Subscribe
Jul 29, 2019 | 09:02 PM
just bought a V class and need to fill up with adblue. Dealer told me, I need to come back to use adblue from Mercedes. and need to replace a filter every tank of adblue.
I just knew that I can buy adblue from service station and is a lot cheaper...
can I use adblue anywhere? are they the same?
where is the filer? d I need to replace the filter every tank?
Kevin
Reply 0
Jul 30, 2019 | 06:57 AM
I buy the cheap stuff at Walmart.
Reply 0
Jul 30, 2019 | 12:48 PM
https://www.walmart.com/ip/BLUEDEF-D...5-gal/16933407
Reply 0
Jul 31, 2019 | 12:43 AM
Volkswagen dealers, $17 the same ISO
Reply 0
Jul 31, 2019 | 02:33 AM
Truck stops pump DEF in the range of $2.50/gallon and it is fresher than the stuff you can buy from the shelf.
DEF in hot temperatures has 6 months of shelf life.
My truck has DEF fill next to diesel fill, so it is easy to use. For MB, I saved cans from DEF I bought in the past and refill at truck stop.
The issue with MB is that fill is inside the trunk and any spill from the pump can make quite a mess, that is why small bottles are recommended.
It is messy job anyway.
I rather leave the tank 80% full, than risk topping it off and spill.
Reply 0
Jul 31, 2019 | 02:57 AM
Any spills from over fills end up on top of the tank. Which isnt inside the vehicle, just an fyi. .
Reply 0
Jul 31, 2019 | 01:49 PM
I use SuperTech DEF from Walmart. It is usually cheaper than Peak BlueDEF.
Reply 0
Subscribe
Currently Active Users (1)
