OM642 EGR / throttle body vacuum connector?
Old Nov 3, 2019 | 10:53 AM
yuril's Avatar
2011 E350 Bluetec
Servo with vacuum inlet on the bottom.
Dear diesel experts,
I am finishing up the oil cooler leak repair (2 days and counting) All looks good on my 2011 E350, except I cannot figure out what kind of vacuum hose was originally connected to the servo attached beneath the EGR pipe. The servo is operating a small 1" round flap, and there is a vacuum port. However, I can't see any small stray tubes around this place, and frankly I don't remember taking any off during the disassembly. Is it optional (the flap is normally open)?
Thanks!
Old Dec 29, 2019 | 06:42 PM
yuril's Avatar
2011 E350 Bluetec
Unhappy Found it, but a new riddle...
Apparently, the part is MB A 642 140 14 63 (changeover flap).
Still, there is no trace of the part (switch over valve) that it is supposed to be connected to it via a vacuum hose. Wonder if this valve is optional on my OM642 version -- there are no hoses connected to the vacuum pump, besides the brake assist line (A 212 430 18 29). Did anyone see this valve actually installed near the throttle body assembly?
Old Dec 30, 2019 | 11:30 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
This engine has NO THROTTLE
I have bunch of pictures I took on my 2008 engine when I work on it, but can't locate such part.
But between year of my engine to the year of your engine MB switched to DEF, so that could create lot of changes.
Old Dec 31, 2019 | 12:41 PM
yuril's Avatar
2011 E350 Bluetec
Yup, lots of changes with Bluetec introduction.
MB A 642 090 02 70 is INTAKE AIR THROTTLE:
http://mbepc.net/3/m/om642/69h/642850/0/14/030
Old Jan 31, 2020 | 04:50 PM
alyqc's Avatar
C63 AMG 2009
hi, if its not done yet ... your vaccum hose from brake booster hose si attach to an switch over valve A0025407097, and vaccum hose from that part to the nipple in your picture...
mine doesnt have any electrical connecteur on this switch over valve ? do you have any one on it ?
Old Jul 3, 2022 | 09:26 AM
00Coupe's Avatar
W212 Bluetec
Where would this switch over valve be located? I am also struggling to find the vacuum line.
