Glow plugs
Old Nov 25, 2019 | 08:52 PM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Hamilton Ontario. Looks like going to be warm tomorrow. 👍
Old Nov 25, 2019 | 09:05 PM
dhurley's Avatar
GL320
Ah darn, If you were in Kansas i'd come assist.
Old Nov 25, 2019 | 09:11 PM
Really appreciate that. Means a lot to me. When you go through the family court machine like I did, you look at things differently....It's hard to find people like you these days... and all those dedicated that come here and share their knowledge.
I'll add, here's a budget leak off setup I just finished. It just needs clear hoses. Will 1/4" be big enough to go over the OM642 injector or 5/16"?
Old Nov 26, 2019 | 04:43 PM
My leak off results:
Few things to note for future reference. On my 2007 E320 with OM642, you want to use 1/4" clear tubing to run the test. If my math is correct and the limit references are correct, the limit should be at 79mm of diesel fuel filled from the neck of the injector return line in this 1/4" ID hose.
Removing plastic return line tops is accomplished easy with 14mm open-end flat wrench. Number 6 was difficult to pull off the injector. I used pliers and the plastic ring cracked. :/ I'll try to create another tool for that in the near future.
So, cranking the motor for 10 seconds and with crank sensor disconnected, I got:
Cylinder 1 - 0.0 mm of fuel
Cylinder 2 - 32.0 mm of fuel
Cylinder 3 - 3.0 mm of fuel
Cylinder 4 - 5.0 mm of fuel
Cylinder 5 - 5.0 mm of fuel
Cylinder 6 - 6.0 mm of fuel
For the second test, I reconnected the crank sensor and run the car cold for 3 min. (It started immediately LOL)
It looked like all injectors BUT No2 where the same. Number 2 cylinder injector returned DOUBLE the fuel compared to the rest of five injectors.
Looks like I need Injector No.2 replaced. It's a start....
Old Nov 26, 2019 | 04:47 PM
dhurley's Avatar
GL320
So, cranking the motor for 10 seconds and with crank sensor disconnectedI got:
Looks like you've found your issue. The max tolarance is 0.5" or 12-13mm. @32mm, you're well above the threshold.
Old Nov 26, 2019 | 04:52 PM
dhurley's Avatar
GL320
BTW heres how you remove those return lines easily. Spray the rings with WD40 right before pulling each one. Then spin the ring in a circular fashion while your pulling up *with your fingers*.
And for the love of god, when you go to replace the injector drive the car 15-20 miles first. You want to do this with the engine HOT. If you do it cold, you risk breaking the hold down bolt in the head. You can reassmble with the engine cold.
Old Nov 26, 2019 | 05:02 PM
  #32
dhurley's Avatar
GL320
Does your scan tool have the ability to recode injectors?
Old Nov 26, 2019 | 05:10 PM
  #33
Yes, Maxi ECU has injector coding adaptation for W211 with OM642.
Old Nov 26, 2019 | 05:13 PM
  #34
dhurley's Avatar
GL320
Excellent. When recoding do not reset any adaptations. Just simply recode and drive. It may hiccup every now and then for a few weeks while the quantity adaptation is being recalibrated over 4 separate pressure levels.
Old Nov 26, 2019 | 09:28 PM
  #35
Wow. The torque on the injector hold down claw is only 7 Nm +90 deg. (MB workshop recommends another 90 deg).
I'm of the opinion that if it isn't broken, don't fix it. But looking at my injector codes, I only had one changed so far. Would you guys recommend pulling them all and resealing with fresh copper washer?
Old Nov 26, 2019 | 09:33 PM
  #36
dhurley's Avatar
GL320
Yes, the bolt torque doesnt need the second 90 degree turn. It does nothing but give you a needless panic attack for fear of breaking.
Its not a bad idea to change the seals out as they WILL eventually fail if they're original. The parts are cheap enough.
Old Nov 26, 2019 | 11:01 PM
  #37
Does any one know what the shear torque is on those T40 M6x1.0 injector claw hold down bolts?
Would like to attempt to take them out safely...
I believe OM642 shear torque on taking glow plugs out is 20 Nm. (Hot engine)
Thanks!
Old Nov 26, 2019 | 11:13 PM
  #38
dhurley's Avatar
GL320
Thanks!
clamp force (7nm + 90 degrees) is about 15ftlb so its at least that. Remove them by hand, no power tools. Its going to sound like theyre breaking but their not. Not going to lie, its nerve racking. But the most important part is to do it hot after a thorough heat soak.
Old Nov 27, 2019 | 03:33 PM
  #39
kajtek1's Avatar
1922 Ford Model T / no OBD
But bear in mind that after those 90 degrees turns, the bolt gets permanently stretched, so there is some margin error.
With my mechanical incline and years of experience, I have a sensor "build-into my hands" where I can sense when bolt is "giving" and avoid shearing it.
But assuming you have time to deal with it.- clean all the "black death" well and soak the bolt with PBlaster or equivalent for 2 or more days.
Old Nov 29, 2019 | 02:31 PM
  #40
What is the exact volume limit in mL that OM642 injectors can pass when performing the leak off test at cranking for 10sec?
Old Nov 29, 2019 | 02:43 PM
  #41
dhurley's Avatar
GL320
0.5" or 13mm
Old Nov 29, 2019 | 05:35 PM
  #42
So with 1/4" inner diameter tube, a rise of fuel upto 13mm mark yields a volume of 0.412mL.
just want to make sure you're considering the same ID of tube as I used (1/4")
I went through MB workshop and could not find a reference value. I've been able to find a reference of 2.5 mL as a limit on sprinter forum. But I can't recall if this was for OM642 or OM648 injectors.
Old Nov 30, 2019 | 02:04 AM
  #43
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
I believe its same for all bosch injectors. I recall reading from some WIS document 20ml/min (you can crank multiple staring sequences until minute is reached)
Old Nov 30, 2019 | 02:49 PM
  #44
Thanks. Managed to pull the glow plug and the injector with such ease... have a peak at the glow plug and the injector tips. So dirty.
I should add that I tested this glow plug and it was under 1 Ohm. The one above is the new one I replaced. Looking at the one i pulled from the engine, seems like it had a lot of deposits. I pulled it just after running the car for 1 hour.
Coding the injector with Maxiecu is really easy. For some reason it saw the injector as #4 position not as #2. I was under impression that the 1st injector from the bumper on the drivers side was position #2. I guess mb software has it as #4.
Old Dec 3, 2019 | 09:47 AM
  #45
Very happy to report that with -10 deg Celsius, car fired right up. Glow plug light stayed on for 4sec. Looks like injector is still calibrating itself as it hiccupsed for few seconds but for $50 cdn, it was a great deal. It came out of 2011 ML. Cheers!
Old Dec 3, 2019 | 12:42 PM
  #46
dhurley's Avatar
GL320
Excellent news. It will hiccup occasionally for another 300-1000 miles until the quantity adjustment corrects itself.
BTW cylinders 1,2,3 are on the passenger side and 4,5,6 are on the drivers.
Old Dec 3, 2019 | 01:45 PM
  #47
This is why I thought it was the other way
File Type: pdf
Old Dec 4, 2019 | 11:21 AM
  #48
kajtek1's Avatar
Almost all manufacturers count cylinder # on V engines between the sides and MB is probably only exception who counts numbers on passenger side starting on front and then switches the count on driver side.
Can get confusing.
Old Dec 4, 2019 | 05:48 PM
  #49
dhurley's Avatar
GL320
Can get confusing.
Ford uses the same designation as MB.
Old Dec 6, 2019 | 05:07 PM
  #50
ot1's Avatar
ot1
2006 E320 CDI
Febi has this INJECTOR kit (https://www.fcpeuro.com/products/mer...ercedes-539384)
grease, seals, bolts, orings for $30 USD
